Old 03-31-2011, 04:01 PM   #1
55 Chevy
55 Chevy's Avatar
Liked 20 Times in 15 Posts
Default Re: Solid Motor Mounts - Good or Bad?
Originally Posted by Robert Simpson View Post
I am looking forward to the Jerico and am on a mission to make it work while retaining my original bench seat.
Allan, we run the bench seat in ours, it is cut out in the center for the stick and the long shifter off the jerico fits just rite. You will ne believe the difference. Did you get the clutchless? Best of luck keep in touch.
Robert
Hello Robert
The Jerico is next years purchase. It will be the regular DR-4 and will not be the clutchless version. Debate will be what will first gear be. Either 3.19 or 3.29. Currently I have a 2.78 in the toploader which is not enough but it is the lowest they go. I am going to see if we can make the Long shifter work without notching the seat. Jerico says no but I made a bracket with the toploader that moves my super shifter to fourteen inches from the front of the transmission. The Long is not nearly as compact as the Hurst so we will see.
Allan
55 Chevy is offline   Reply With Quote
