Liked 286 Times in 73 Posts
Has anyone towed a trailer from Roanoke VA to Charlotte NC via:
US220 NC68 US158 US311? If so, can you advise for or against it? Thanks |
Liked 56 Times in 27 Posts
Dave Ribeiro 1033 STK |
#3 | |
Liked 44 Times in 13 Posts
US 220 to NC 68 to I 85 to Charlotte I 81 South to I 77 South to Charlotte I would go the I 81 and I 77 route myself..... JMO
Mack Reeves 2377 STOCK & SUPER STOCK |
take i-81 to i-77 south unless you are worried about scales (around mm 106 in nc). the route you quoted has too many small towns, traffic (school busses), lower speed limits. from roanoke to zmax should be less than 3 hours doing the posted speed limit. only short cut would be to take exit 18 off i-77 and go east (harris blvd) - you would save a few miles going into charlotte and then back north on i-85 (depending upon the time of day you could save 15 to 30 minutes. andy b.
Liked 83 Times in 32 Posts
Dont go that way, I killed the brakes on my truck going that way a few years ago, I81 to 77 is the only way, and buy gas in Wytheville, cheapest gas you will probably find on your trip. And dont hit Charlotte early AM going south on 77, after 9am you will be ok.
#6 | |
Liked 7 Times in 5 Posts
The I-81 and I-77S is the best way if the weather is good. I-77 has a section on Fancy Gap mountain that is a killer in bad weather. I would guess six or seven deaths in the last few months. Even if the weather is clear the wind can be very rough. good luck, Roland |
