#11 |
Liked 36 Times in 26 Posts
Boy, I just can't believe NHRA would not see this as a safety problem, After reading about how the throttle stuck open on the previous, and how the hand brake saved the day, it would probably be in the best interest to make a secondary braking system, mandatory on all cars. I know a Mustang in division 3 super gas that pulls the chute at the end of the run, to help out his braking. This way he would not have to pull the chute and use the hand brake to help stop. I guess I would not be able to race cause I can't turn the steering wheel with one hand, and if I am braking hard I like to have both hands on the wheel. I am starting to realize that the class I am in the wrong class, And I liked the class.
#12 |
Banned
#13 |
Come on CBS, any word yet?
Thanks, BB |
#14 |
Liked 4 Times in 2 Posts
I've sent 2 notes.....waiting on a response....
#15 |
#16 |
I see the SRAC has a lot of pull these days. Did they even have the regular meeting in Gainesville like they have in years past? I don't remember reading anything about it...
Jason Oldfield S/G & S/St 1838 |
#17 |
#18 |
One things for sure, they are not pulling on a hand brake. But realy guys, you can use a dual master cylinder, with 2 resivours and get the same redundant system your after without the drama of "I want a hand brake". Unless your left foot does not work. Otherwise I tend to agree that the temptation to use the hand brake as a finish line enhacing tool does exist.
Jeff Beckman 318J ET, SG 318T SC |
#19 |
Jeff, could you explain how you can use a dual resivor master cylinder and it only work one set of calipers at a time but will work the second set when the first set goes out?
We are not wanting 4 calipers working at the same time, that will kill people! We are trying to make our cars safer in the case of a failure of the first set of normal brakes....like I had a BG last year and luckily the tech guy saved my life or at least my car by letting me keep the second brake handle in the car.
Lynn Ellison |
#20 |
it works them both, how would that kill you?
