Old 04-12-2011, 07:20 AM   #1
Bobby Fazio
Bobby Fazio's Avatar
Liked 4,379 Times in 502 Posts
Default Reduce bouncing when coming down from wheelstand
Hey guys, my car is hooking well and doing about 3 foot wheelie but when it comes down the front tires are bouncing back up in the air. Right now I am using ladder bar set for maximum weight transfer and double adjustable front QA1 shocks. I have extension all the way down to softest setting zero and compression set pretty stiff. Which do you think I need to move? Thanks.
'65 Mustang SS/L & L/SA
Old 04-12-2011, 08:00 AM   #2
Mike Pearson
Mike Pearson's Avatar
Liked 1,946 Times in 587 Posts
Default Re: Reduce bouncing when coming down from wheelstand
If the car is bouncing the shocks are still too loose. Tighten the compression as tight as the shocks will go. The QA1 shocks might not get tight enough to control the bounce. I have Santhuff double adjustables on the front of my car. They are expensive but they will stop the bouncing
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
Old 04-12-2011, 05:31 PM   #3
Marty Rinehart Jr
Marty Rinehart Jr's Avatar
Location: Rineharts Performance Race Cars, Thomasville,PA
Liked 333 Times in 75 Posts
Santhuff
Marty Rinehart Jr
1125 SS STK SG SC SST
Marty Rinehart Jr is offline   Reply With Quote
Old 04-12-2011, 07:08 PM   #4
Liked 1,892 Times in 423 Posts
Yep, Santhuff.
And dial in only the amount of bite you need. any excess wheel stand slows you down and worsens bounce. Take extension out until it stops hooking, and then loosen it back up a couple of clicks. That will keep it from bouncing back up.
Old 04-13-2011, 12:54 AM   #5
Adger Smith
Liked 880 Times in 311 Posts
Move weight forward in the car and don't spend so much time in the air!
Adger Smith (Former SS)
