Old 04-23-2011, 01:10 PM   #41
Bob Pagano
Bob Pagano's Avatar
Liked 16 Times in 11 Posts
Default Re: Holroyd BBC Rocker Arms
Mike I dont know about that, I was breaking rockers on my 427 vette in 1976. The motor in question was built by Ralph Truppi, ran like a raped ape but always broke a rocker when you least wanted it. 427-400 tri power, glide, long slot rockers, stock springs.
Bob Pagano A/SA
Old 04-23-2011, 03:21 PM   #42
Jeff Lee
Jeff Lee's Avatar
There is no going back, might as well stop fantasizing about it. The options are ammend the rules to either allow non-OEM in appearance such as shown here or allow an aftermarket replacement; which is entirely what these Holroyd rockers are anyway.
If NHRA wants to inhibit RPM and performance by keeping a stock OEM rocker then thats fine, enforce the rules. If NHRA wants to allow racers a better rocker that doesn't break (yes, always at the wrong time!), then allow Holrod are Crane, it really doesn't matter since neither look or perform as intended from the OEM.
And I believe shaft rockers should be where shaft rockers were placed by the OEM & stud rockers where placed by the OEM.
Jeff Lee 7494 D/S '70 AMX
Old 04-23-2011, 04:49 PM   #43
Bob Pagano
Bob Pagano's Avatar
Jeff, They are GM rockers, the only BB rocker you can buy first and second Clark had the mod approved by nhra. What more dose one need to do, he went thru the channels, is that west coast ? I dont think so, everybody on the east coast has them too. I could care less, I poked my nose in because I told Clark and a few others where to find the marine take-off rockers. I wish I had them in 76.
Bob Pagano A/SA
Old 04-23-2011, 05:30 PM   #44
Bob, I don't see anything incorrect here.
Old 04-23-2011, 05:42 PM   #45
Originally Posted by Bill Edgeworth View Post
They are legal for engines other than big block Chevy’s and have been for quite a while. And they don’t break just because of spring pressure; opening ramp is the predominant reason in my opinion.
Bill,
What other engines are they approved for? Do you have a picture? Approx cost?
Thanks
Old 04-23-2011, 05:55 PM   #46
Bob Pagano
Bob Pagano's Avatar
Mark, it dont effect me I dont use them. Weather or not legal or not it was nhra that gave the go ahead. Besides the mod the rocker is the same as before, it is bigger in the pocket for the 9/16 ball that helps spread the pressure better. When used with Alum heads I have seen them pull the stud out so there is still a problem waiting to happen, ask Kevin Helms.
Bob Pagano A/SA
Old 04-23-2011, 09:34 PM   #47
Bill Edgeworth
Bill,
Thanks
Mark,
I have direct knowledge that they are approved for Pontiac and Olds engines. If you like I can take a picture but it looks exactly the same as the BBC modification. Clark only has the one insert to my knowledge. The first time I talked to Clark he said to send him a set of the rockers I wanted modified and he would let me know if he could fit his insert in. They fit, he welded them in and I have not broken a rocker since. I couldn’t go 12 passes without breaking one. And for Mike; that’s in a motor with only 364 lift at the valve and 150# seat pressure.
And for those who are not using them and would like to but don’t know if they are approved I would suggest you do exactly what I did; I asked my division Tech Director if I was allowed to modify my rocker arms like the ones approved for BBC’s . Dave wrote back to me saying he was unsure and asked me not to run them until he consulted Glendora. Few days later he wrote back saying Bruce said they are approved.
Cost was around $250 to have Clark do rockers I supplied.
Bill Edgeworth 6471 STK
Bill Edgeworth is offline   Reply With Quote
Old 04-24-2011, 11:52 AM   #48
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 313 Times in 106 Posts
with weaker springs most time breakage comes from valve float or bounce which beats valvetrain to death most of the time when you have float the keeper grooves will be burred
and have to dress them down to get valve through guide and valve seat will be wider where valve has hammered it.
I believe alot of rocker breakage with higher spring pressure is from flex,they get wiggled to death. Which I say Clark's rocker reduces.
You break studs or pull threads out of head most likely there is valve float.
You may agree or disagree but stocker valve train have been push to edge and over whether in spring pressure/duration,overlap checked rules or current rules,and no matter what the rules are they will still be on the edge,because most everyone is going for all they can get.
Mike Taylor 3601
Old 04-24-2011, 02:43 PM   #49
Bill Edgeworth
Here are some close ups of Clarks work.
Name:	download april 24 11 060 (1024x678) (640x424).jpg
ID:	6980   Click image for larger version
Name:	download april 24 11 061 (1024x678) (640x424).jpg
Old 04-24-2011, 11:05 PM   #50
Jeff Lee
Jeff Lee's Avatar
Thanks...how about a bottom view on the pushrod cup?
