Old 04-24-2011, 12:42 AM   #11
Rory McNeil
Liked 1,104 Times in 302 Posts
Default Re: 1964 Ford Falcon Sprint V8
Plus as mentioned, all 260 blocks use the oddball 5 bolt bellhousing, which means that the later C4`s won`t bolt up, and until recently, a 5 bolt SFI scattershield was unavailable, but Quick Times does now list one. You could convert the Falcon to a 65, but even then, I believe that the 289 in the Falcon is 2 barrel only.
NHRA 6390 STK
M/S 85 Mustang
Old 04-24-2011, 01:18 AM   #12
Liked 5,125 Times in 1,953 Posts
You could always sleeve down a 289 block if it was a good combo..
It's not!
Old 04-24-2011, 08:51 AM   #13
BlueOval Ralph
Banned
Can't make 64 into a 65 was totally new body
BlueOval Ralph is offline   Reply With Quote
Old 04-24-2011, 09:27 AM   #14
Tim Ellis
Liked 7 Times in 6 Posts
Can't make 64 into a 65 was totally new body?.... um, no, 64 and 65 falcon, same body, different grill and tail lights
Tim Ellis is offline   Reply With Quote
Old 04-24-2011, 11:12 AM   #15
jmcarter
jmcarter's Avatar
Liked 3,184 Times in 973 Posts
What classic looking cars though. Any of you guys know if a 9 inch tire will even fit?
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 04-24-2011, 12:09 PM   #16
Mile High
I use a 9" out of a 69 Torino ( not cut down) 15x8 wheels with 5 1/2" back space. Had to push out the fenders and cut the wheel opening on the front for clearance. The tire is a 275 -15 Hoosier DOT radial and 28" tall. Not much room left.
Another difference is the body side moulding. 64's is wider apart than the 65's.
Jeff
Street legal 64 Falcon Sprint with 410W living in Texas.
Stock - Super Stock fan
Mile High is offline   Reply With Quote
