Old 05-13-2011, 10:25 AM   #1
Mile High
Default Re: Pedal mounted 2 step switch
I've been using the 2 step since 1996 and I have a switch on the dash. Do the burn out throw the switch then once in high gear turn it off. It's such a habit that while at the Nitro Jam in San Antonio ( footbrake class) I kept reaching for the switch. A brake pressure gauge would probably keep you more consistant . The factory 64 Falcon brake light switch that screws into the master cylinder is what I use.
A friend of mine wired his to the brake light switch on his 72 Nova at first and it worked well. Then he drilled and tapped the master cylinder to use the Ford pressure brake light switch and he says its reacts quicker. He doesn't have a line lock but does use a low gear only switch for the 2 step.
Jeff
Street legal 64 Falcon Sprint with 410W living in Texas.
Stock - Super Stock fan
Mile High is offline   Reply With Quote
