Joe, We used old slicks off of Ed Bednaz's B/stick nova on Alan Peters Jr.'s 66 impala wagon and they worked real well. The car yanked the wheels nice but then kicked the driveshaft upstairs.......ooops!
Liked 13 Times in 7 Posts
Your question is what if you use bias tires on a automatic car, right? My experience is you will lose one tenth in et. Second, the air pressure will be lower. How much lower you would have to test. In the past you wanted to wrinkle the side wall in a bias tire and not wrinkle the side wall in a radial. I run 18 to 24#'s in my radials. Anything lower and they stop working. I would think the bias would be 18# and lower until it hooks right.
Richard Grant 4988 STK |
#3 | |
Liked 20 Times in 14 Posts
I run Toyo's on may J/SA Cutlass. They say the Toyo's are made for a stick car, but as cheap as they are I tried a set. I run 1.55 to 1.58 sixty foot times. They are also very consistent. I run 15psi on a 8" rim.
Alan Warman STK 4107 |
