Old 05-24-2011, 04:02 PM   #1
Ian Hill
Ian Hill's Avatar
Liked 6 Times in 3 Posts
Default 327/ 275 - 350/330 crate short block
G/SA combo - 327 ci with Paul Bestor carb, Brzezinski intake, heads from Steve Fercassi,
engine originally from Mike Walter, new valves spring, engine runs strong $5500
ATI glide w/2.08 1st gear, fresh by Joes Transmission N.Falls $1600
as a package, with G/SA converter and micro polished 5.60 gear set (used but in good condition). $6500
350/ 330 chev crate bottom end complete. Firroavantti custom engines built round crank engine with flat tops, coated, eagle replacement rods, ATI balancer. Approx 75 runs turning 7200 rpm - 11.05 at 119 in I/CM at 3580 lbs chevelle - $2000
trades accepted for 2006 or newer LS style vette engine and trans with computer!
also interested in 396 to 540 ci streetable (less than 550 hp) big block ready to run.
Ian
905-704-9105
Ian Hill is offline   Reply With Quote
Old 05-24-2011, 05:36 PM   #2
Mike Savelle
Liked 7 Times in 5 Posts
Default Re: 327/ 275 - 350/330 crate short block
check your PM
Mike Savelle is offline   Reply With Quote
Old 05-29-2011, 10:20 AM   #3
Robert Swartz
Robert Swartz's Avatar
If you weren't clear up in Canada. I'd be interested in that crate motor shortblock. Freight down this way would be a pain, plus, be no one here to unload it, when a truck came.
Robert Swartz - Swartz & Lane 66 Chevy II Pro
95 Achieva EF/SA, 78 Mustang II U/SA (work in progress) #354 stock
Robert Swartz is offline   Reply With Quote
Search this Thread:
Advanced Search
