Old 05-25-2011, 07:27 AM   #31
Daran Summerton
Daran Summerton's Avatar
Liked 66 Times in 37 Posts
Default Re: TH350 Clutches / Modifications
http://classracer.com/classforum/att...1&d=1306412666
72 cutlass
Daran Summerton is offline   Reply With Quote
Old 05-25-2011, 08:48 AM   #32
Bob Pagano
Bob Pagano's Avatar
Liked 16 Times in 11 Posts
Hay Mark, Wont a 6cyl spring work with that combo, I remember Fedun used them. What bushings are in your A- frames? That combo should Jump up with no problem.
PS Great looking car
Bob Pagano A/SA
Old 05-25-2011, 11:10 AM   #33
Liked 1,893 Times in 423 Posts
Originally Posted by Daran Summerton View Post
http://www.globalwestperformance.com...trut-rods.html
Mark it's all bolt on so I don't forsee a problem. I believe your right on the gearing and the rear suspension being bound up (Tight) I truly wish I just had the factory rear arms with the factory springs at this point. Something is dead wrong.
Daran,
I'm not sure the front suspension pieces are legal, and they certainly are not necessary. I'd get a ruling, in writing, from NHRA tech. Actually, I just wouldn't buy them. If the cars can be made ot work well in Stock Eliminator without them, and they can, then there's no reason to buy them, that's money better spent elsewhere.
I'd be taking the shocks and springs off, and checking the suspension on both ends for binding, and correcting what I found. Then I'd look at the upper bar mounting locations on the rear housing, as you were talking about earlier. After that, I'd take the 2.75 low back out, swap to a 6.17 in the rear, and see about getting the stall speed up around 6200-6600.
Old 05-25-2011, 06:08 PM   #34
Daran Summerton
Definately more gear and converter, right now gonna work on suspension until I can get some daylight under the tires. If anyone has a front spring part number I'd love to hear it. I will probably use fresh control arm bushings with teeth removed. I'll keep you all updated if I find the problem. Thanks everyone
72 cutlass
Old 05-25-2011, 06:20 PM   #35
Daran, I'd go Del-A-Lum if I were going to keep the car, along with low friction ball joints, and long uppers. The Del-A-Lum stuff with grease fittings will stay free and work well forever. That's a job you only want to do once.
Try 6 cylinder or small block 3 speed springs, that should do it, usually Advance or the 'zone can get them.
Old 05-25-2011, 09:18 PM   #36
Kenney Kelley
Liked 72 Times in 36 Posts
Darin I might have the parts you are looking for. If you are interested you can call me at Home # 321-632 2171 cell# 321- 412-5196 . Kenney Kelley
Last edited by Kenney Kelley; 05-26-2011 at 05:54 AM. Reason: another phone number
Kenney Kelley is offline   Reply With Quote
Old 05-26-2011, 06:50 AM   #37
Daran Summerton
I will call you Kenney, looking for stock rear control arms and a drivers side front strut rod for a 65-66 Thanks
72 cutlass
