Old 06-03-2011, 02:19 PM   #1
Liked 10,965 Times in 2,260 Posts
Default Re: Live from Englishtown , NJ - NHRA Supernationals
Troy if the clutch is slipping why does the tach not move? Is it an example of acceleration curve not matching the one set in the computer, and then the computer adjusting the air intake to make it match? I always thought the clutch slipped or the tires spun with the tach always moving forward!
Old 06-03-2011, 02:37 PM   #2
Frank Castros
When was the last time Peter Biondo, Anthony Bertozzi and Dan Fletcher all went out in the first round of Super Stock?
Old 06-03-2011, 03:07 PM   #3
Liked 17,532 Times in 1,595 Posts
Here is the helmet cam on Micheal Iacono racing Anthony Bongiovanni. I will have more photos of Super Stock later on today.
Old 06-03-2011, 02:45 PM   #4
Mike Fuller
Liked 203 Times in 80 Posts
Larry, these cars have a built in sensor that only allows them to accelerate under full power in a heads up situation. It took a lot of time and effort to accomplish this but it is proving to be well worth it.
Mike Fuller 396 STK
3961 SS
Old 06-03-2011, 04:18 PM   #5
Tim Kish
Liked 11 Times in 4 Posts
I see guys are icing down the blowers on the Mustangs - they will eventually figure out that can be a bad thing - If you cool the case down with hot rotors inside then the rotors will rub the housing at start up taking the rotor coating off and causing the unit to loose efficiency once it comes up to temp. Or worst case the unit will seize due to rotor OD contact. It will be an expensive learning experience.
Tim Kish
3032 SS/GS
Tim Kish is offline   Reply With Quote
Old 06-03-2011, 05:29 PM   #6
lugnut
Cool Re: Live from Englishtown , NJ - NHRA Supernationals
no no no that ice is for the other guy in the other lane for his heads up as wip that he is about to recieve for his head ache
lugnut is offline   Reply With Quote
Old 06-03-2011, 05:54 PM   #7
Jeff Colvert
Jeff Colvert's Avatar
Liked 3 Times in 2 Posts
Talking Re: Live from Englishtown , NJ - NHRA Supernationals
Hey Larry, The tach only moves foward or up if it is tire spin, when the clutch slips its like it on the conveter in a auto. just kinda sets there for a instant then catches up and goes on.
Jeff Colvert SS/G,F,GT/B 4456
Jeff Colvert is offline   Reply With Quote
Old 06-03-2011, 06:33 PM   #8
Friday nights are for the Pros - that way we can get together with friends and chow down along with some beverages and bench racing .Here are a few photos I took before first round this morning ..........
Jack Matyas is online now   Reply With Quote
