Liked 203 Times in 80 Posts
Larry, these cars have a built in sensor that only allows them to accelerate under full power in a heads up situation. It took a lot of time and effort to accomplish this but it is proving to be well worth it.
Mike Fuller 396 STK 3961 SS Last edited by Mike Fuller; 06-03-2011 at 03:07 PM. |
Liked 11 Times in 4 Posts
I see guys are icing down the blowers on the Mustangs - they will eventually figure out that can be a bad thing - If you cool the case down with hot rotors inside then the rotors will rub the housing at start up taking the rotor coating off and causing the unit to loose efficiency once it comes up to temp. Or worst case the unit will seize due to rotor OD contact. It will be an expensive learning experience.
Tim Kish 3032 SS/GS |
no no no that ice is for the other guy in the other lane for his heads up as wip that he is about to recieve for his head ache
