Old 06-05-2011, 06:46 PM   #2
Jeff Lee
Jeff Lee's Avatar
Default Re: SBC replacement main caps - Stock
Originally Posted by Robert Swartz View Post
I acquired an "010" block from a local circle track racer that had quit. The block hasn't been bored or worked on, other than the main caps are missing. My question, what's the policy on replacement main caps in stock, both NHRA and IHRA? As long as it's the same material, weight, appearence as OEM. Is there anything I need to look out for.
You can put anything you want in. Don't forget new caps require a line bore / hone.
Jeff Lee 7494 D/S '70 AMX
