Liked 719 Times in 220 Posts
Sunday,I took my Chevelle to Irwindale for Summit Race #3. Car is a 327,250/245 horse, large journal steel crank, Powerglide trans, 8 3/4 converter, not sure of the make, 5.38 gears, etc. etc. and on the first time only, the engine let go about 250 feet out. It locked up solid. I instantly shoved the trans in neutral and rolled off the end of the track and off the first return road. No oil on the track, water in the oil, etc, engine is locked up solid. A 3 foot breaker bar wouldn't move it either direction. I was wondering if the sudden engine failure hurt the converter. It wasn't all the way up in first yet, probably 5-5500 max,car didn't lock the rear wheels for a bit, just wondering what you guys think if I hurt the converter. I'll probably pull the engine in a weekend or two. Not what I needed. ('>')?
Greg, I would definetly send it in. Probably find a name on it when you get it out.
Ed Wright 4156 SS/JA |
Liked 239 Times in 114 Posts
If you can't turn over the engine, then it becomes tricky to get the converter unbolted from the flexplate. Pull the engine and trans as one. Pull the trans and leave the converter bolted up, be careful to pull the trans straight out of the converter. You should be able to get the converter bolts off once the trans is removed. It is probably safe to have the converter checked out, but if the engine stops suddenly, but the trans is still spinning, it is kind of the opposite of letting your tires hook up while doing a burnout. It causes the sprag to overrun, which won't do any damage to it. I bet your converter is OK.
Liked 5,146 Times in 1,964 Posts
I'd say probably not , under the circumstances.
Engine stops, the pump, or impeller portion of the converter stops too. The stator may have been freewheeling, but the fluid pressure coming off the turbine would have been minimal, so it wouldn't have loaded the sprag too abruptly. Then again, if you don't know what you have there, it's probably time to take a look anyway. PM me if you'd like more info.
#5 | |
Sponsor
Liked 59 Times in 12 Posts
