Liked 19 Times in 5 Posts
My guess is there is not enough valve lash,the reason it starts good when cold tells me from experience that the valves may have recessed into the seat,if you check the compression when its hot there will be hardly any,and the valves will be held slightly open,check the valve lash
Liked 3 Times in 1 Post
Thanks for all the help on here and also to Gene Monahan. After removing the carb and disassembling it, I found nothing wrong. Completely clean of any varnish or debris. Still, I cleaned every passage and blew everything out. Reassembled and reinstalled. Magically, it runs and starts like new again. ???
You know this means it WILL do it again, but only when its 100 outside and I really need it..... Wade O |
