Old 07-20-2011, 05:27 PM   #1
Dave Ribeiro
Liked 56 Times in 27 Posts
Cool Re: help
I would try another carb, Holley, AFB , Q-Jet, etc to see if it slows down or picks-up ??? Also, how about a Chassis Dyno ??? They can find lots of things and save you Time & Money, no to mention pulling
all your hair out ... Maybe a bad connection / ground or a wire over heating ? It's always tougher when it doesn't miss or backfire etc ...
* Keep us informed & good Luck....
Dave Ribeiro 1033 STK
Old 07-20-2011, 07:37 PM   #2
Tony Curcio
Tony Curcio's Avatar
Liked 4 Times in 1 Post
Default Re: help
If you lost the three tenths between the last week of June and the first or second week of July, consider the radical weather change. If you were jetted a little rich last month, you are way too rich in the oppressive gunk we've had for air this month.
Change your metering rods, and you might regain half of what you lost.
Tony Curcio 1860 STK
Tony Curcio is offline   Reply With Quote
Old 07-20-2011, 07:54 PM   #3
Ed Wright
Ed Wright's Avatar
Default Re: help
Have you been logging your air/fuel with a wide band? You should do that, besides tuning it's a good reference when something like this happens.
Ed Wright 4156 SS/JA
Old 07-20-2011, 07:59 PM   #4
rgarvey
Default Re: help
no its just been slow since may very consistant but slow
rgarvey is offline   Reply With Quote
Old 07-20-2011, 08:52 PM   #5
Ronnie Hamlin
Liked 29 Times in 8 Posts
Default Re: help
I had a very similar problem many years ago with my 71 Duster stocker. Changed everything, ignition, fuel system, trans, convertor, etc. etc. Nothing I did made any difference so far as being faster or slower. Turns out the 8 3/4 rear end housing had bent after MANY years of use and abuse. I didn't have a brace welded on at that time. The way I found it was I was going to install my spare hogshead to see if that was the problem. It was near impossible to remove the axle shafts. It might be worth looking at.
Ronnie Hamlin is offline   Reply With Quote
Old 07-20-2011, 09:01 PM   #6
rgarvey
Default Re: help
thanks i will tear it apart thursday after work i dont have a backbrace either and its old rear end
