Old 07-20-2011, 08:52 PM   #1
Ronnie Hamlin
Liked 29 Times in 8 Posts
Default Re: help
I had a very similar problem many years ago with my 71 Duster stocker. Changed everything, ignition, fuel system, trans, convertor, etc. etc. Nothing I did made any difference so far as being faster or slower. Turns out the 8 3/4 rear end housing had bent after MANY years of use and abuse. I didn't have a brace welded on at that time. The way I found it was I was going to install my spare hogshead to see if that was the problem. It was near impossible to remove the axle shafts. It might be worth looking at.
Ronnie Hamlin is offline   Reply With Quote
Old 07-20-2011, 09:01 PM   #2
rgarvey
Default Re: help
thanks i will tear it apart thursday after work i dont have a backbrace either and its old rear end
rgarvey is offline   Reply With Quote
