Liked 55 Times in 26 Posts
Just wonderin what everyone uses.... Fixing to replace my hooker competitions.. (basically a street header)
Dynatech. Call Kevin Cradduck at NitroPlate.
Alan Roehrich 212A G/S |
Liked 269 Times in 99 Posts
Check out Schoenfeld .
Some of there stuff is pretty good and not expensive.
Liked 91 Times in 51 Posts
Those are both excellent choices above.
I have a 68 Camaro SBC with solid frame/engine mounts and run 1 7/8" Hooker Super Comps. You do not need to make any dents in the pipes to fit our chassis. I do have to lift the driver side of the engine and they slip right in. Power Steering and Power Brakes. I also run an extension off of them as the "torque tube". They helped make hp to 7000 rpm without a dip. ![]() |
