Old 08-18-2011, 06:23 PM   #1
Dave Ribeiro
Liked 56 Times in 27 Posts
Wink Re: Fuel pressure
What else did you do to the rebuild ? Bigger needle & seats, replace gaskets, check surface straightness, etc ? That's why I asked about what you can do to Pure Stock rules.. There is a big diifference between a rebuild & a race carb from a good builder ? You should see if a local racer has tricked out Race WCFB carb you can try ... I know you will see a big difference , there's alot of inturnal works that you can't see from the outside ? Check-around , I am sure there are some Stock & S/S guys that can help you in your local area... Alot depends on the car & how hard it leaves, Stick or Auto ??
Good Luck ...........
Dave Ribeiro 1033 STK
