Old 08-28-2011, 06:10 PM   #1
Ron Gusack
Ron Gusack's Avatar
Liked 7 Times in 6 Posts
Default TH400 shifter
I currently use a Turbo Action shifter. I have a bad habit of shifting to N at the stripe and the lockout handle is close enough to the main T handle that I sometimes shift to R. I know I'm a dumb ***, so you don't need to tell me whai I already know. Is there a shifter that is more idiot proof than the Turbo Action? I'd like to extend the space between the 2 handles and I've tried to call Turbo Action, but haven't gotten an answer.
I've looked into a clean neutral VB, but TCI doesn't have any and doesn't know when they will make more. The Griner VB requires the trans brake to be functional and I run foot brake stuff.
Ron Gusack is offline   Reply With Quote
Old 08-28-2011, 09:12 PM   #2
Joe DeMarzo
Liked 113 Times in 9 Posts
Default Re: TH400 shifter
I use the hurst shifter with a reverse lockout, easy to go to neutral from third but cant go to reverse without hitting a lever. Used it on a 400, then a 350 and now the metric. The lever is out of the way and you can not hit it by accident.
Joe DeMarzo 1317 STK
Joe DeMarzo is online now   Reply With Quote
Old 08-28-2011, 11:22 PM   #3
Ron Gusack
Ron Gusack's Avatar
Joe, Does it take 2 hands to get to reverse from neutral?
Old 08-29-2011, 08:00 AM   #4
cad
cad's Avatar
Liked 91 Times in 51 Posts
If it is this one, the answer is no. Once you are in neutral, you push the small lever forward, and then move the handle to neutral/park.
http://www.jegs.com/i/Hurst/530/316-0001/10002/-1
Old 08-29-2011, 09:52 AM   #5
Joe DeMarzo
Ron, the one I have takes two hands but that is my routine, could probably due it with one hand but you still would have to let go of the shifter or have a really long thumb.
It is not the quarter stick.
It is a pistol grip...and it is my way of KISS. Both Jegs and summitt sell them.
Old 08-29-2011, 10:00 AM   #6
Ron Gusack
Ron Gusack's Avatar
Thank you for your help. Can it be shifted from 3rd to N quickly, like coming out of the water? Does the cable come out of the shifter toward the front of the car or the rear?
Old 08-29-2011, 10:31 AM   #7
Hurst QuarterStick, front exit cable. Hurst QuarterStick II, rear exit cable. Simple, effective, reliable, safe.
Old 08-29-2011, 01:00 PM   #8
Dwight Southerland
Dwight Southerland's Avatar
Liked 780 Times in 194 Posts
Jerico. Push in the clutch.
Old 08-29-2011, 09:31 PM   #9
Barry Polley
Guest
Posts: n/a
http://www.precisionperformance.com/home.htm
Best shifter I have owned. Fool proof and yes you can get the clean neutral. Simple, light and never fails.
Old 08-30-2011, 03:04 PM   #10
Geerhead55
Liked 5 Times in 5 Posts
Talking Re: TH400 shifter
Now THATS funny! Good one Dwight.
Danny Durham
