Old 08-31-2011, 01:49 AM   #11
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Default Re: 84/85 Mustang Stocker
Auto in an 85 yes.....carb no FI yes
Old 08-31-2011, 12:34 PM   #12
Pat Cook
Well....I'll just keep my old Fairlane then....
67 Ford Fairlane
F/SA
749
Pat Cook is offline   Reply With Quote
Old 08-31-2011, 12:48 PM   #13
Chris1529
Liked 70 Times in 29 Posts
unless I am mistaken, the 85 with the cfi/auto doesn not have the roller cam either.
Chris Bowman
The Mountain State Mustang
1984 Mustang GT350
Old 08-31-2011, 03:47 PM   #14
Dave Turner
Dave Turner's Avatar
Liked 364 Times in 138 Posts
You are correct Chris....rated at 175hp I think.
Dave Turner
SS/GT #1153
Old 08-31-2011, 06:16 PM   #15
ALMACK
ALMACK's Avatar
Liked 372 Times in 130 Posts
X3 on the 85 CFI flat tappet.
That CFI throttle body is tiny. Not sure what it is rated at cfm wise, but I would venture to say it's no more than 350 cfm.
I looked at the 83-85 CFI combo for years with my 83 Thunderbird 302, but deemed it a waste to try due to the super small t.b....plus it's h.p. is factored too high.
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
Old 09-01-2011, 08:02 PM   #16
mtkawboy
Liked 54 Times in 18 Posts
Dyer has told me he's done the intake test too with the same results, but it is what it is. Havent talked to him in a while so I dont know how the SS car is doing
mtkawboy is offline   Reply With Quote
Old 09-02-2011, 04:28 PM   #17
Michael T Johnson
Pat,
It depends if you want to run IHRA or NHRA. IHRA in April 2007 listed this on their website
4/30/2007
All vehicles classified as stick or auto only, accepted to use automatic when listed as stick only, and accepted to use stick when listed as automatic only.
This is listed in the IHRA STK/SS horsepower adjustment section of the website. I run the 85 carb combo as an automatic. In the 1/4 mile with good weather conditions my combo will go one second under the index. My car is a natural N car, I added weight to take the car to O/SA. As everyone has mentioned, the intake manifold is the biggest issue with the combo. I've used the stock " 85 Holley carb", and a Holley 1850. I didn't see much difference in performance. However, my car is most happy when run a little rich. I also recommend using a low gear set in a C-4. Hopefully this helps you in some way.
Mike
Michael T Johnson is offline   Reply With Quote
Old 09-02-2011, 05:57 PM   #18
ALMACK
ALMACK's Avatar
Originally Posted by Michael T. Johnson View Post
Pat,
4/30/2007
Mike
Thanks for the info Mike.
I didn't know that.
I had thought about the 85 Mustang carbed combo 2 years ago, but since I am a bracket racer, I didn't like the idea of trying to make a manual trans car consistent.
Now I might reconsider and convert my 91 Coupe to look like a 85.
I/PS '95 Mustang GT
Old 09-02-2011, 09:19 PM   #19
7423
Almack
I wanted to build a carb auto combo 3 years ago. I wrote and called Bruce and my D7 tech guy using that IHRA ruling as my basis. It took them about 4 months to tell me "Ford never built it, you can't race it". Its all good, I think the 94-95 is a better combo now that I have played with one.
7423 is offline   Reply With Quote
Old 09-03-2011, 10:40 PM   #20
greg fulk
greg fulk's Avatar
In IHRA you CAN run an auto in a1985 GT with a carb! I had a 91 rag top I was going to make into a SS/GT car IHRA yes NHRA no though the guide showed a Merc for years as having it....the Nick Morris won NHRA Div.3 Championship with that combo then oh hell no not legal!?
