#21 |
Liked 174 Times in 39 Posts
Go for it! You might have to take that throttle stop off and go fast enough to get around 90 HP though.
3207 D/SA, C/ED |
#22 |
Liked 633 Times in 88 Posts
I will be in columbus with the same parts I had at INDY. We will see if I get to race?
Andrew I am game for anything. If I were to get 50 hp I could run E/SA at #2970. I don't see all the crying over a little 281.
Charley Downing 3548 STK |
#23 | |
Liked 1,436 Times in 299 Posts
I would probably get my rear kicked even racing you in E, but I sure would like a shot at it. Better than trying to race you in J anyway. You have the power to get to E all by yourself. Just run her out a few hundered feet more. LOL.
James Schaechter 3163 STK |
#24 |
James just put the 283 back in her and we can race all the time. I will even give you a small head start. Even if I beat you I can't pass tech.
Charley Downing 3548 STK Last edited by Charley Downing; 09-21-2011 at 08:44 AM. |
#25 | |
I thought Ford fixed their clerical error on the parts anyway. Not done yet ?
#26 |
No the clerical error is fixed.
Just for you James I will run it balls out to 800ft this weekend.
#27 |
Don't get too wild, people will think you got a bromance going for us 283 racers.
#28 |
Liked 797 Times in 165 Posts
Well, since this thread is about CJ engines, I do have a question
do the 428, 352, and 281 engines that are being run in stock use a conventional style intake manifold with a throttle body on top like the Drag Paks use ?
Dave Casey 1330 STK |
#29 | |
Liked 7 Times in 5 Posts
The 352 and 428 use an intake and throttle body similar to the Drag Pak. The 281 uses the standard type fuel injection system. regards, Roland |
#30 |
Liked 26 Times in 13 Posts
The352 and 428 engines are old windsor SBF based pushrod motors which do use a conventional intake with a four barrel throttle body. The 281 is a mod-motor, overhead cam engine, but I think it uses the OEM style intake (composite/plastic?) with a newer style single hole TB.
Bill Harris ex 2172 STK ex 2272 S/S |
