Liked 1,434 Times in 299 Posts
Don't get too wild, people will think you got a bromance going for us 283 racers.
James Schaechter 3163 STK |
Liked 794 Times in 165 Posts
Well, since this thread is about CJ engines, I do have a question
do the 428, 352, and 281 engines that are being run in stock use a conventional style intake manifold with a throttle body on top like the Drag Paks use ?
Dave Casey 1330 STK |
#3 | |
Liked 7 Times in 5 Posts
The 352 and 428 use an intake and throttle body similar to the Drag Pak. The 281 uses the standard type fuel injection system. regards, Roland |
Liked 26 Times in 13 Posts
The352 and 428 engines are old windsor SBF based pushrod motors which do use a conventional intake with a four barrel throttle body. The 281 is a mod-motor, overhead cam engine, but I think it uses the OEM style intake (composite/plastic?) with a newer style single hole TB.
Bill Harris ex 2172 STK ex 2272 S/S |
#5 | |
The 281 uses a dual bore throttle body. The part number is M-9926-3V and each bore is 62 mm and it is also available with mechinical linkage. Part number M-9926-3VM. regards, Roland |
