#11 |
Liked 10 Times in 10 Posts
On the 1967 Z-28 302 engine.
The block casting #3892657 used for 1967, was a 327 small journal block. 2.299" mains / 2.000 rod journals And with 2-Bolt Main Caps. A special forged steel crankshaft (casting #3815882) was 'tufftrided'. I've heard of the 283 67' Camaro,,,,,never realized it was an 'export only car',,,with a 4-speed. But after some research,,,,,found out they were assembled in Switzerland. Last edited by Paul Ceasrine; 09-23-2011 at 03:17 PM. |
#12 |
Liked 599 Times in 137 Posts
I'd never heard of the car, either. You learn something every day.
This trumps my previous weirdest Camaro - the new 67 SS350 I saw sitting on a dealers lot with a bench seat and a 4 speed. It had some ungodly gears in it, I'm thinking either 4.56 or 4.88. It was that dark turquoise green with redline tires, painted wheels, and bottle caps. It sat there for quite a while and then disappeared. I never saw it again, not even at the tracks in the area. I don't think the 396 had been released yet, so this would have been the ultimate Camaro at the time. |
#13 |
Liked 783 Times in 195 Posts
The '67 302 engine used the formentioned 657 block, "green" rods from the solid lifter 'Vette engines (which were the small journal version of the famous "pink" rods), a special crankshaft that was nitrite treated, the 30-30 solid lifter Corvette camshaft, foged pistons that had a dome similar to the original dome on the high-cormpression 327s, 2.02-1.60 valve 462 casting number heads, the unique intake manifold, 780 cfm Holley (actually the design carb was a 585 cfm carb, but it never made production), and the Corvette flat windage tray. The intake and carb made the package the killer.
The strangest engine that never made production was a 3-2bbl 350 with the Corvette 350 hp hydraulic cam and big valve heads. If you ever see a copy of an original assembly manual, there are several pages devoted to the installation details of that engine, including a drawing of the engine that used a triangular air cleaner similar to the one on the 3-2bbl Corvettes. Chevrolet had intended a small block package that would have mimicked the big block engines released in the Corvette that year. Production costs and less than acceptable performance in the warranty tests (remember that was the first year for the 5-year, 50,000 mile warranty) caused them to nix it. They were also aware that Ford was stuffing a big-block into the Mustang, Pontiac had planned from the beginning to put a 400 in the Firebird and Chrysler was releasing the 383 in the Barracuda and Dart. They needed a big-block offering so the 396 got the nod over a high-perf small block on the street. All that info was related to me by a GM engineering manager who worked on the Camaro project. I was introduced to him when I was building my Z28 stocker in 1979. |
#14 |
look in a late 60s or early 70s Motors manual and you'll find specs for a 67 Camaro 350 horse 327. I guess the story was that Chevy was considering the 327/350 before the 350/295 was done.
#15 |
Liked 54 Times in 18 Posts
A buddy of mine had a 327/325 4 speed in a 68 Nova that was basically a 327/350 only with a Q-jet. I havent seen one of those since, it was a 1 year only deal I think.
#16 |
I had a friend that had that engine in a 67 4 speed Malibu. It was pretty strong though it had some highway gears.
#17 |
Not to muddle up this thread.
But the 327/325HP (Engine Code L-79) was usually found in the 1968 Chevelle Malibu (non-SS car),,,,,,,4-speed only. Kind of a rare car/engine combo too. |
#18 |
Liked 333 Times in 180 Posts
L79 was the hot lick in the 66-67 Chevy II---Grumpy won a lot of races with his too--my partner has an original 66 L79 Chevy II Hard top NO ITS NOT FOR SALE he has had that car for 25 years now--damn thing is quick
#19 |
Liked 53 Times in 25 Posts
I also had a friend when I was in high school that had the same combo. His had gears the car was fast.
Dennis P Chapman 1904 STK NHRA National Record Holder Car Owner. |
#20 |
Liked 100 Times in 45 Posts
So I guess that 283 camaro was running stock at a non sanctioned NHRA track?
Former NHRA #1945 Former IHRA #1945 T/SA |
