Old 09-27-2011, 08:52 AM   #4
Terry Cain
Terry Cain's Avatar
Liked 231 Times in 107 Posts
Default Re: Stamped rockers?
Originally Posted by art leong View Post
Have any of you that have used stamped rocker arms. Had them wipeout on the valve tip side?
What are the causes (other than lack of oil) ?
I'm using a cam that is much bigger than a stock cam. And I destroyed 12 out of 16 rockers
Yes, I have. Come to find out it was the rockers. They were suppose to be the "all high mighty nitro" rocker which (no names) one of the cam manufactures sells. Chinese steel junk.
I found a set of OEM and did hardness testing against the Chinese rockers. WORLD of difference. I suggest checking hardness. Should be at least 40-45 on rockwell C scale.
Terry Cain ???? STK
tcain19689585@gmail.com
Terry Cain is offline   Reply With Quote
