Old 10-16-2011, 09:12 AM   #1
Liked 10,838 Times in 2,253 Posts
Default Re: Live from the Fall Classic
Very good work Beth, thank you!
Old 10-16-2011, 09:36 AM   #2
Beth Denysenko
Beth Denysenko's Avatar
Thanks everyone!
I have a bunch of pictures to post, I will have all afternoon to do so as I lost first round....my rear brakes hung up and I couldn't leave the line on time or run my number due to the drag. Grrrrr.
Tony's still in though, and we have yet to run Superstock....
Beth Denysenko P/SA 330
www.moneymakerracing.net
Beth Denysenko is offline   Reply With Quote
Old 10-16-2011, 10:24 AM   #3
Jason
Liked 6 Times in 4 Posts
Did everyone make it through teardown?
Jason is offline   Reply With Quote
Old 10-16-2011, 11:12 AM   #4
Andrew Hill
Andrew Hill's Avatar
Liked 174 Times in 39 Posts
Everyone except the Carey Bales. Apparently that car was one of the first few built, and the spec on the piston dome was changed after the motor was built. It still has the original pistons, so the dome was quite a bit too big.
Charlie, your damn right I complain about the CJs and DPs. Give me a set of heads as good as theirs and the D/SA record would be 9.39, not 10.39.
At an open, the 1.00 under rule doesn't apply, so it's just the 1.20 under rule. No one got horsepower, although the Challenger would have gotten 14 if it had passed teardown.
3207 D/SA, C/ED
Andrew Hill is online now   Reply With Quote
Old 10-16-2011, 12:33 PM   #5
Marty Buth
Liked 232 Times in 39 Posts
Congrats to Andrew and all of the other folks that set records at the Fall Classic!
Marty Buth 3657 STK
Marty Buth is offline   Reply With Quote
Old 10-16-2011, 01:04 PM   #6
Jason
[QUOTE=Andrew Hill;288105]Everyone except the Carey Bales. Apparently that car was one of the first few built, and the spec on the piston dome was changed after the motor was built. It still has the original pistons, so the dome was quite a bit too big. QUOTE]
So an engine that came stock from Chrysler with original pistons will not pass tech?
Oh I forgot, those were not real cars. Looks like regular production cars that you would buy new at a dealer are not legal to race in Stock. Now how wrong is that? And what does that say for the future of Stock?
Old 10-16-2011, 04:14 PM   #7
Charley Downing
Liked 653 Times in 89 Posts
Andrew I think you have a good set of heads. How can you complain about CJ's you just beat one in the class final at columbus and now you just took the record. In the words of your dad you must be a PIG.
I was told in April of this year at the NC nationals from two different tech men that all runs at national open count towards AHFS.
Charley Downing 3548 STK
Charley Downing is offline   Reply With Quote
Old 10-16-2011, 07:05 PM   #8
442OLDS
442OLDS's Avatar
Liked 282 Times in 103 Posts
Thumbs up Re: Live from the Fall Classic
Congratulations to Matt Antrobius.He has a picture of the trophy on his facebook page,so I have to assume he won.Maybe the results will be on DRC tomorrow!
Old 10-18-2011, 09:21 PM   #9
NewHemi
NewHemi's Avatar
[QUOTE=Jason;288122][QUOTE=Andrew Hill;288105]Everyone except the Carey Bales. Apparently that car was one of the first few built, and the spec on the piston dome was changed after the motor was built. It still has the original pistons, so the dome was quite a bit too big. QUOTE]
QUOTE]
Ummm, let see now. He blew it up/broke it, in Indy a few weeks before, and now he is running again. You surely can't be saying that the engine hasn't been apart and then back together at a minimum... I am not saying that the pistons were replaced, but certainly they were all of the way out of the engine, and then back in. And apparently nobody bothered to check dome height.
And as I said before, the dome height issue/requirement was NEVER a secret.
So was the illegal dome height on his pistons an innocent mistake, or was it an intentional attempt to gain an advantage?
Only he knows which it is.
But everyone else plays by the rules (We were torn down and found legal, including dome height...) and the rules are the rules, so why shouldn't he be held responsible?
David
The New Hemi Guy
NewHemi is offline   Reply With Quote
Old 10-18-2011, 09:48 PM   #10
Conway Witten
Conway Witten's Avatar
Does the rule book say anything about height? It just says same type dome of dish as an OEM piston. That is an OEM piston, right? If it cc's let it go.
Conway Witten is offline   Reply With Quote
