Old 10-20-2011, 05:05 AM   #1
Ben Kallies
Default Re: Help!! Engine Miss
Dion,
I sent the carb back to Deano and made him aware of the issue. He completely disassembled the carb, and checked all of the passages. Everything looked good.
Dirk,
Thanks for the offer to help. I've got family in LaCrosse - beautiful area. Ground wires are my current focus. I'll be changing some things around even if it doesn't prove to be my problem.
Nitroman,
I plan to eliminate the vehicle wiring from the equation one way or another in the testing process. I think I'll start with what Alan suggested and run all MSD wiring straight to the battery to eliminate the rest of the vehicle wiring from the equation. If that doesn't do it, the next step is an HEI to eliminate the ignition as well. The second MSD box that I tried was brand new, and will be in retested in another vehicle this weekend or next, so that will confirm whether or not that box is good.
-Ben
Ben Kallies is offline   Reply With Quote
Old 01-22-2012, 05:59 PM   #2
Ben Kallies
Well, it's winter in WI, and I had to put my car to bed without having found a solution to the mysterious engine miss. I did however, make some progress in November.
I installed a brand new HEI distributor with a single wire going direct to the battery. In theory, this should eliminate the entire ignition system from the equation. Needless to say, the problem persisted.
With the HEI still in place, I installed another carburetor that Dean Oliver was kind enough to let me try. The carb was fresh, and set up for a small block, and a bit leaner than my other carb. With this setup, the miss was definitely less severe, but persisted nonetheless.
Feeling pretty confident about the state of the ignition and fuel system, I turned my attention back to the engine. I pulled the covers, and checked and reset all the valves. #4 intake was bit loose, but the rest looked good. I can't think of any other mechanical issues that would cause a miss like this.
I've got a couple of months to let the brain gears turn before I can go back to actually working on the car (damn non-heated garage), so I'd love some input regarding a good springtime game plan. We'll get it figured out eventually. Thanks
-Ben Kallies
Old 01-22-2012, 07:41 PM   #3
Greg Reimer 7376
Liked 719 Times in 220 Posts
Cool Re: Help!! Engine Miss
I thinkI'd start looking for a flat cam, especially an exhaust lobe.
Old 01-22-2012, 08:48 PM   #4
MAURICE BLENDHEIM
Liked 284 Times in 87 Posts
Ben... I would start with a compression test. You mentioned intake lash, any chance something didn't fall into the intake manifold between the dyno and chassis (maybe paper towel or a piece of rag) I would have a look at that intake valve spring also. From what I read it is a miss load or no load. For the heck of it check it again... 1-8-7-3-6-5-4-2. Good Luck!
MAURICE BLENDHEIM is offline   Reply With Quote
Old 01-22-2012, 09:41 PM   #5
Pvt Parts
Pvt Parts's Avatar
Two issues that I ran into with similar results. Super Stock Corvette.... fresh motor with engine miss. Looking at it at the track and thinking about pulling it out. I looked down and pulled on the main starter wire, the big one on the solenoid with the battery cable attached to it. It was loose, real loose like someone forgot to tighten it on install. Tightened the nut and the problem was fixed.
New Jerry Haas Comp car. Fouling plugs and killing coils in 4 to 5 runs. Chased the problem for half of the season. Finally drilled two holes in the frame tubes and ran a #10 wire from the frame tubes to each head under the header bolt. Problem fixed.
Maybe this will help. Good luck.
Old 01-23-2012, 01:09 AM   #6
Adger Smith
Liked 880 Times in 311 Posts
You have a PM
Adger Smith (Former SS)
Old 01-23-2012, 09:19 AM   #7
terry1
Liked 24 Times in 13 Posts
Smile Re: Help!! Engine Miss
Ben.You have a PM
terry1 is offline   Reply With Quote
Old 01-23-2012, 02:48 PM   #8
dartman
dartman's Avatar
Liked 68 Times in 41 Posts
Originally Posted by Ben Kallies View Post
Dion,
Dirk,
Nitroman,
-Ben
have you tried a different carb?
1231 FS/D Drag Pak
1231 E/SA 71 Demon
Kelly MacKay
dartman is offline   Reply With Quote
Old 01-23-2012, 10:51 PM   #9
Adger Smith
Ben,
I built a new engine for a customer and it missed and popped from the very first time we started it. Took it out of the car and put it on the dyno and all was fine. Changed everything in the car we could think of. The last thing we changed was the master cut off switch. We should have changed it first.
Old 01-23-2012, 11:26 PM   #10
Pvt Parts
Pvt Parts's Avatar
Originally Posted by Adger Smith View Post
Ben,
Now that you mention it, I've heard of that happening before.
