Liked 11 Times in 8 Posts
Ok I know this has been discussed but I'm working on my engine after having all the seats in both heads replaced. Now figuring that my stem heights, and seat depths would be moved I decided I'd better do some checking on this thing figuring my piston to valve clearence may have changed.Well when I put the rocker stand at the correct height, as per T&D's instructions which I had followed in the past I'm seeing .025 inch less lift at the valve and my roller swipe pattern on the valve tip is WIDE over .200 inch. This seemed odd to me so I put the stand back to the height I had always run it which is about .090 lower, now I'm seeing the correct lift at the valve and my swipe pattern is less than .100 wide near tip center. With the stand raised the pattern looks OK till over half lift then it start running hard to the int. side. What the heck am I seeing here and why would moving the stand lower than it should be cause this change? I'm using adjustable pushrods for this setup, maintaing 1 turn from seated on the rocker adjuster screw. What gives? Since I'm not an engine builder I need some feed back from some of the pros. Thanks for any replies. Joe
Joe Buchanan SS/BX 3117 |
Liked 880 Times in 311 Posts
Joe,
You have a PM
Adger Smith (Former SS) |
Liked 50 Times in 14 Posts
Adger, your reply doesn't help the rest of us OR MAKE for interesting reading like the cam timing thread on here. ;-)
Isaac Zane STK 1237 J/SA Buick Apollo Patriot Guard Rider DOOF 43 |
LOL Isaac.
Alan Roehrich 212A G/S |
Ok,
This is what I told Joe, aaaaaaaaabbbbbbbbbccccccccccdddddddddddeeeeeeeeeef fffffffffggggggghhhhhhiiiiijjjjjjjkkkkkllllllmmmmm mmnnnnnooooopppppqqqqqrrrrrssssssttttvvvvvvvwwwwww xxxxxyyyyyyyzzzzzzz.... Isaac, Hope I didn't leave anything out. Please forgive my Arkansas drawl. :~)
Adger Smith (Former SS) Last edited by Adger Smith; 11-11-2011 at 06:57 PM. Reason: sp |
I know Adger doesn't like to post technical advice publicly and i understand why. I;m just glad he takes his time to help me, as has many on here I've learned alot and hope I learn much more.Thanks Adger us young guys(LOL) sometimes need guidance. Joe
#7 | |
Liked 705 Times in 219 Posts
Greg, yes I've been moving stand down and looking at the effects it has in lift and roller travel on the valve tip. lowering it does "fix" some of what I'm seeing wrong just didn't understand why I'm having to set it differently from where T&D wants it which is how I had always set it up. I understand that with new seats things have moved around that's why I'm double checking things versus just bolting them back on, thanks for your input I'm obviously going to put it where I have my correct lift numbers and least amount of roller travel just seemed odd that I'm having to move it this much. Based on T&Ds "tool" they send I have had to move the stand down .150 inch lower than the "gauge" shows.
#9 | |
