Liked 409 Times in 113 Posts
Put a fuel cell in my stocker this season and was wondering what is protocol for winter storage. Should I drain it completely or ??? Plastic cell with foam inside. Thanks for any tips. - Joe
Joe Huestis "Annie's Song" Racing U/SA 2724 Youngsville, NC |
first step is to get the foam out before it clogs something up. then just drain it
Chad Rhodes 2113 I/SA |
#3 | |
Jim Wahl....NHRA #2239 S/SS - IHRA # 8 Stock, D2 Stock Champion (forever I guess) 2019 Baby Gators Stock Champion 2009 NHRA D2 National Open Stock Champion 1982 NHRA D2 West Palm Beach LDRS SS Runner Up Past President, Southern Stock / Super Stock Association. ![]() |
Liked 54 Times in 7 Posts
Not to hijack this thread but the replies prompted me to ask the question since a fuel cell is the winter project on my car.
Is removing the foam just part of the winter draining process, or should the foam not be used on a drag car? Thanks Chad |
Do NOT use the foam ,......unless you enjoy headaches. It breaks down and will plug everything.
Dion Hildebrandt 6009 STK H/SA |
Liked 2 Times in 2 Posts
Pulled the foam out after replacing pump,going thru carb and regulator and flushing lines etc.Not worth the hassle or $$$ it cost me.
Nautilus Racing |
It can also make you fail fuel check if you switch fuels.
Liked 101 Times in 27 Posts
Put the Marvel Mystery Oil In......let the engine run for a while.........forget it.
There appears to be very strong opinions on both ways........foam in and foam out. C'mon guys........Which is it?
We've left the foam in w/o any problems Definitely run Marvel Mystery throught the entire fuel system........cell to carb. I'm sure everyone has witnessed residue from racing fuels especially VP ! |
#10 | |
As to foam deteriorating , there are several reasons that it might . One , the foam in race fuel cells is not exactly the same foam as you find at the local Home Depot . Foam not designated for fuel won't work , at least not for very long . Another reason for foam deteriorating is mixing of fuels . Gasoline requires one type of foam . Alcohol fuels , including E fuels will require a different foam . Some manufacturers may have a foam that they feel is compatible with all types of fuel . Ask their opinion . And sunlight harms the foam , so don't take it out of the cell and leave it on the work bench over the winter . |
