Old 11-14-2011, 08:45 PM   #1
joe huestis
Liked 411 Times in 114 Posts
Thumbs up Proper Fuel Cell Winter Storage
Put a fuel cell in my stocker this season and was wondering what is protocol for winter storage. Should I drain it completely or ??? Plastic cell with foam inside. Thanks for any tips. - Joe
Joe Huestis
Youngsville, NC
Old 11-14-2011, 08:47 PM   #2
Chad Rhodes
Default Re: Proper Fuel Cell Winter Storage
first step is to get the foam out before it clogs something up. then just drain it
Chad Rhodes 2113 I/SA
Old 11-14-2011, 09:04 PM   #3
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Thumbs up Re: Proper Fuel Cell Winter Storage
X2, get that foam out pronto! Jim
Old 11-14-2011, 11:35 PM   #4
Chad E532
Chad E532's Avatar
Liked 54 Times in 7 Posts
Not to hijack this thread but the replies prompted me to ask the question since a fuel cell is the winter project on my car.
Is removing the foam just part of the winter draining process, or should the foam not be used on a drag car?
Thanks
Chad
Chad E532 is online now   Reply With Quote
Old 11-15-2011, 12:39 AM   #5
Dion Hildebrandt
Dion Hildebrandt's Avatar
Thanks
Chad
Do NOT use the foam ,......unless you enjoy headaches. It breaks down and will plug everything.
Dion Hildebrandt 6009 STK H/SA
Dion Hildebrandt is offline   Reply With Quote
Old 11-15-2011, 09:39 AM   #6
Chris DeGidio
Chris DeGidio's Avatar
Liked 2 Times in 2 Posts
Pulled the foam out after replacing pump,going thru carb and regulator and flushing lines etc.Not worth the hassle or $$$ it cost me.
Nautilus Racing
Chris DeGidio is offline   Reply With Quote
Old 11-15-2011, 10:53 AM   #7
Chad Rhodes
It can also make you fail fuel check if you switch fuels.
Old 11-15-2011, 11:15 AM   #8
Rusty Davenport
Liked 101 Times in 27 Posts
Put the Marvel Mystery Oil In......let the engine run for a while.........forget it.
Rusty Davenport is offline   Reply With Quote
Old 11-15-2011, 11:15 AM   #9
Reed Granrt
Chad, my man
What can be added to make you fail, can be added to make you pass also. Think about that for a second. Oh wait a minute it will take you longer than a second to figure that out. HeHe.
reed
Reed Granrt is offline   Reply With Quote
Old 11-15-2011, 11:43 AM   #10
buzzinhalfdozen
Liked 11 Times in 8 Posts
I've found it best to remove fuel cell and store it somewhere the temp is consitent. The cell can and will sweat during temp swings and produce condensation. Of course if your vehicle is not subjected to these swings just draining would be in order. IMO. Joe
Joe Buchanan SS/BX 3117
