Old 11-20-2011, 12:48 PM   #1
Wade_Owens
Wade_Owens's Avatar
Liked 3 Times in 1 Post
Default Re: header tube size
Either size will work well on a 350. Don't fall into the "equal length" trap. Just buy a merge collector from Performance Welding. The larger header may want to be shorter on the primaries. If you don't buy a merge collector, consider buying or building a header that fires in rotation into the old style collector. But, the bottom line is, it's all theory until you get an ET slip........
Wade O
Old 11-20-2011, 06:50 PM   #2
chassis1
Liked 9 Times in 3 Posts
Wow, Wade you sound like a real header builder......lol...but you forgot to tell him about the steps in the header and what purpose they serve....
1.625 is the way to go and when you measure that exhaust port, I bet it is really close to that size.....
Chassis1
chassis1 is offline   Reply With Quote
Old 11-20-2011, 08:02 PM   #3
Wade_Owens
Wade_Owens's Avatar
Chassis1
Lol, I've wasted enough money on headers and hardly ever see a gain. Use the KISS method.........
Wade O
Old 11-21-2011, 12:35 AM   #4
chassis1
for the combination you run, there are very interesting ways that are not simple to make the small engines move more air then ever thought. Believe it or not, it is done with the 4 into 1 and not the tri-y because of the cfm of the smaller heads......sometimes you can speed the air up too fast and the smaller engines do not like it.....
Chassis1
Old 11-21-2011, 01:27 PM   #5
Wade_Owens
Wade_Owens's Avatar
Chassis1
Old 11-21-2011, 05:31 PM   #6
Jeff Teuton
Liked 325 Times in 50 Posts
Here is what we got; 360 motor wedge 1 5/8 to 1 3/4 to 1 7/8 with merge collector, 370 motor hemi; same size one runs to 7k, the other past 8k, the 370 liked a 1 3/4 to 1 7/8 about 5 better one made 540, one made 660.
Jeff Teuton 4022 STK
Old 11-21-2011, 05:56 PM   #7
Ed Wright
Ed Wright's Avatar
Strangely, mine doesn't appear to like step headers. Been running them (1 3/4" to 1 7/8") since last year, but I have never even had the thing on a dyno until recently. Bought them on the recomendation of someone I really respect. The step headers only appear to help down around 5000 RPM. Past that straight 1 7/8" picked it up everywhere. If I were foot braking they might be worth more. Wonder what I'm doing wrong, that it doesn't appear to like them, when everybody else runs them?
Thinking about trying a set of 2" primaries? My old, original-1975-rules-292" C/SM Camaro loved 2" headers. But, it was a stick car leaving over 8000. This is a 358" LT1 trans brake car, the converter hits about 6000.
Ed Wright 4156 SS/JA
Old 11-21-2011, 06:34 PM   #8
MEXJOE
MEXJOE's Avatar
Liked 165 Times in 51 Posts
Unhappy Re: header tube size
BOY! You said it !
I've got a bunch of expensive stuff I'm gonna make into wind chimes and try to sell on E-BAY.
"Tune around what you have" is the best advice I ever got.
Wade O
MEXJOE is offline   Reply With Quote
Old 11-21-2011, 08:07 PM   #9
chassis1
everyone seems to forget that the cam is still the brain of this deal when it comes to headers. most of the time, off the shelf STOCKER cams are still very old designs and are not made to be as efficient as some headers are built or bought, no matter what your engine guys chooses.....truth is most engine guys miss on the cam and go to what they call, " ol' reliable cams...." but yet the racer seems to think better than the engine builder sometimes...and looks at his WHOLE combination......
Chassis1
Old 11-22-2011, 12:44 AM   #10
K Stubbs
Liked 20 Times in 3 Posts
I know a racer that ran a 69 Camaro 350/255 auto stocker. He had a set of Kromer (sp?) step headers that were 1/12 - 1/58 - 13/4. He blew out a tube at a race and put on a straight 13/4 on that side and did not affect performance one bit. He ran it like this for a couple of years and won class many times including Indy. Like Wade said, unless you are way out in left field there is probably not a big performance difference in them.
K Stubbs is offline   Reply With Quote
