#21 |
Thanks Mickey. Couldn't agree more although I didn't want to be the first to say it here. The COPO version certainly doesn't help. The aspect ratio is simply miserable.
#22 |
Liked 172 Times in 46 Posts
327, 5 speed cross, it over like a comp car at 10,400, could run high 8's
Dirk Olson 5036 STK |
#23 |
The last good looking Camaro was the first generation...............................
#24 |
Liked 3,219 Times in 980 Posts
I may be a Mopar guy but agree with you 1000%. Truly a classic. I would love to have one if they weren't so expensive.
#25 |
WHOOO 9's right out of the box.
The Chevrolet COPO Camaro development group was in Bradenton, Fla., with the prototype version of the factory-prepared race car making shakedown runs on Monday. The group kept the car’s performance under a shroud of secrecy as they made several runs with the scoreboards turned off. Longtime class racer Mike Pustelny is the driver putting the new Chevrolet through its paces. We are told the car has already made it into the 9's despite a mild launch. A source tells CompetitionPlus.com that this COPO was built at Pustelny's MPR Race Cars shop with direction from Russ O'Blenes, Robin Wright, and Mark Kent of Chevrolet Performance. PHOTOS: TESTING IN DECEMBER ![]() |
#26 |
What's that thing weigh? Heard the NA/427 will fit into A/SA.
Jerry Williams NSS/A, E/S, PRO E.T. And the "Grandaddy" of Gen III Hemi Performance...The fire inside me still burn's. |
#27 |
327/2.9 327/4.0 Suggested class A Stock AA Stock A Super Stock Cubic inches 427 (7.0L) 327 (5.3L) 327 (5.3L) Block LS7 LS9 LSX Block material Aluminum Aluminum Cast iron Bore x Stroke (in.) 4.125 x 4.100 4.065 x 3.150 4.065 x 3.150 Crank Forged steel Forged steel Forged steel Rods H-beam H-beam H-beam Pistons Forged dome Forged dome Forged dome Compression ratio 13.5:1 10.2:1 10.2:1 Heads LS7 LS7 LS7 Induction natural boosted boosted Intake Holley 2.9L Whipple 4.0L Whipple Camshaft type Hydraulic roller Hydraulic roller Hydraulic roller Cam duration (deg.) 233/276 @ 50 244/255 @ 50 244/255 @ 50 Cam lift (in.) .595 .650 .650 |
#28 | |
Liked 7 Times in 5 Posts
regards, Roland |
#29 |
Yep, your correct. 438"
Ed Wright 4156 SS/JA |
#30 | |
Some prefer to call it "Pushing the Envelope". 8-)
Scott Wilcox 2193 3x National Champion SS/A, SS/B, SS/K, SS/L, SS/AM, A/SM, C/SM, B/A, C/A, G/A, H/A |
