#1 | |
Liked 7 Times in 4 Posts
Bob Aceves, 746 E/SA A&M motorsports |
The lower the fuel temp , the better . Just a few degrees won't make a huge difference in performance , but every little bit helps .
Restrictions in the fuel system will increase fuel temps , but not enough to cause a major loss in performance . Running the fuel line near any source of high heat will have much more of an effect . As the fuel temp goes down , the density changes . So jet accordingly and then cool the fuel the same way and for the same duration before each run . Last edited by Mike Croley; 12-27-2011 at 12:12 PM. |
Ian, you don't have to re-tune the car for cold manifolds and cold fuel to help. You are mistaken there. Btw, you need to fix that black smoke at start-up. That tends to wash oil from the cylinder walls, which is a ring seal killer.
Ed Wright 4156 SS/JA |
