Old 12-19-2011, 10:54 AM   #18
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
Default Re: Q-jet and Holley
Turbine is used to mearsure air flow (cfm) engine is using,usaully has cat (carb air temp) sensor mounted in it also.
My engine does'nt make near that power, pure stocker,my Q jet will match HP all way through and have about 3lbs. torque less @ peak than 750 holley. I compared on 351C on time w/ my q,jet 750&850 dbl. pumps and had same results.
I leave turbine off and mount cat sensor on carb to where it picks air temp going in carb so correction is repeatble.
Mike Taylor 3601
