Liked 20 Times in 14 Posts
Thanks all.
Bottom line then is a radical cam needs A LOT of spring pressure regardless of rpm range??? |
Liked 6 Times in 3 Posts
i have been adding shims along the way this year and the motor has liked it each time i did it. F/CM 350 ci 330 hp. shift at 6500 and cross at 7200. i haven't heard the coils binding yet, so i am going to add another shim under the exhaust side for the next race and see what happens :-) i love this sport!
i look forward to the day i cross the line and the car shuts off and the parachute deploys automatically....in my stocker! LOL Ian |
#3 | |
#4 | |
Jeff Lee 7494 D/S '70 AMX |
Dink, dink, dink, dink, ......
Bub Whitaker |
it sounds a lot like the head of a valve coming out the header collector.
Chad Rhodes 2113 I/SA |
Ahh, you have gone too far too! My "valve through the exhaust" sounded like a death rattle at 1100 feet. Ended by splitting the piston in two, one half embedded in the block, half way up the bore, the other half scattered throughout the other 7 holes!
It was actually caused by coil bind, but I'd imagine similar results if it did happen. I have been increasing valve pressure buy .01" shims and am up to .06" intake and .03" exhaust over recommended and each time I add shims the car picks up. The next race I go to I will be matching the ex with the intake. It is a largerjump than I've done so far, but I am guessing it will be good as I did the intake first and have been catching up with exhaust with good results. I've discussed this lots with my engine builder and we decided to go with the idea that more is better, to the point we wipe the cam shaft out. This will be season two coming up, the last cam had three seasons without fail. As far as telling you what my spring pressure is, I don't think it matters. My combo likes the springs stiff. Just like valve lash, my combo runs near to zero as I dare go... I set them cold and I set them tight. But that's for another thread I am sure. What I will tell you is at what spring pressure I wipe the cam out...if it happens. I switched Joe Gibbs oil this past seaon, this is the first time I am not freshening my engine, everything, including the cam looks good. I figure I'll get to coil bind before hurting the cam. Ian |
Your kidding about "getting to coil bind", right? .050" from coil bind should be close enough.
Ed Wright 4156 SS/JA |
Liked 880 Times in 311 Posts
Ed,
Don't you remember...?? You want it to coil bind just as it reaches the peak of the "Loft" or "Toss" off the cam profile?
Adger Smith (Former SS) Last edited by Adger Smith; 12-24-2011 at 02:28 PM. Reason: sp |
#10 | |
Ed Here you go again. You missed it. You put in a safety factor of setting it up to get .05 before you get max lift. That way you cant ever float the valves. Ive been doing this for years and I aint never floated a valve. Well wait a minute I think I floated a couple out the headers. HeHeHe reed |
