#11 |
We've toyed with idea of running one in SS. With an intake and some heads.....
#12 |
Liked 10 Times in 10 Posts
Joe Kenney
Hopewell Junction, New York 'The Trick Tank' 1962 Dodge Model 440, 3-Seat/9-Passenger Station Wagon 383/343 HP * Set '7' National Records with this car....... 1969 * G/SA,,,,,,,National Record Holder * Top 5 Points Leader 'NED 1' * G/SA Class Winner,,,'First Annual' Eastern Canada Can-Am Championship * Stock Eliminator Champion,,,,'First Annual' Eastern Canada Can-Am Championship 1970 * H/SA,,,,,,National Record Holder,,,,,, (110.99 MPH) * Top 10 Points Leader 'NED 1' * Stock Eliminator Champion,,,'NED 1' Stockers Bonanza (Dover Drag Strip) * H/SA Class Winner,,,,,,Indy Nationals * Stock Eliminator Semi-Finalist,,,,,Indy Nationals * SuperNationals,,,H/SA Representative (Semi-Finals of Stock Eliminator) 1971 * H/SA Class Winner,,,,,Summernationals * Third-Round Stock Eliminator,,,,,Summernationals Last edited by Paul Ceasrine; 01-12-2012 at 07:57 AM. |
#13 |
Liked 2,738 Times in 965 Posts
We know Jimi Vignogna owns the Behemoth but where is the Trick Tank today?
#14 |
1970 Photo
Dover Drag Strip Big Stockers Meet in 1970,,, "NED 1 Stockers Bonanza' A ton of New Jersey Racers headed up to New York to participate in this Big Money Event. 64 of the top Northeast Stockers attended. Championship Run, "Banana 1", 1957 Chevy Model #150, 283/250 HP (Class M/SA),,,,,Frank Iaconio versus "The Trick Tank", 1962 Dodge Model #440 Station Wagon, 383/343 HP (Class H/SA),,,,Joe Kenney National Records at the time; M/SA = 13.50 H/SA = 12.55 Last edited by Paul Ceasrine; 01-01-2012 at 09:08 AM. |
#15 |
Dave,
The 383/343 HP engine was an 'early-Chrysler Race Motor', developed in late-1962,,,,,,,for the Dodge Polara 500. It could not be ordered as an engine option in the 1962 Dodge. It was strictly an 'over the counter' performance parts bolt-on application, to be fitted on the 383/330 HP engine. A few (not many) of the 1962 Dodge Polara's and 1962 Station Wagons were equipped with the 'special order' 383/330 HP 4-Barrel engine,,,,,, also known as the 'police pusuit package'. Included were; * Camshaft ((Mechanical),,,(Lift .445 Intake / .445 Exhaust,,,,, Duration 294*,,,,,, Overlap 55*) * Solid Lifters * Adjustable Rocker-Arms, w/special locking-nuts * High-Strength Steel Pushrods * Chrysler 300-J Cylinder-heads (Casting #2402557) (Closed chamber 66.5 cc, with 2.08 Intake valves and 1.74 Exhaust valves) * High-Rate Valve-Springs w/damper (100 lbs. w/valve closed,,,,,,199 lbs. w/valve open) * High-Strength Valve Spring Retainers * In-line Dual-Quad Cast Iron Intake Manifold * Twin Carter AFB carburetors (500 CFM) (1 7/16" x 1 9/16") * Special High-pressure 3-valve fuel pump * Dual-point distributor * Special Long-branch exhaust manifolds Note: In May 1966, the NHRA approved the 383/343 HP engine combination for the Plymouth 'Sport Fury' and Station Wagon. Note: In 1967, the NHRA permitted the use of the 1967 440/375 HP (#2780915) 'Hi-Po' cylinder heads on this engine. Last edited by Paul Ceasrine; 01-08-2012 at 08:17 AM. |
#16 |
Liked 89 Times in 19 Posts
The earliest 383/343 example I can remember in Division 7 was a '62 Dodge driven by Jim Johnson (not THE Jimmie Johnson) of Hermosa Beach, California and later by Joe Ross. I recall that it was run regularly in 1963 and was a record holder in 1964 (see attachment). I believe that it was a Polara 2 dr. hardtop and I'm sure that it had bucket seats.
Chuck Norton |
#17 |
Chuck,
The mid-year (1962 1/2') 383/343 HP in the Dodge Polara 500 and/or Plymouth Sport Fury combination knocked off another Mopar for B/SA in 1963. In early-1963, the 'Hot Combination' for B/SA was the 1961 Plymouth Fury 'Hardtop Coupe' with the 'Optional Dodge Engine' (413/375 HP 'Cast iron In-line Dual-carbed engine). But by mid-year 1963, the secret was out, and the 'lighter' 383/343 HP cars were out-running the 'bulky' 1961 Plymouth's. Last edited by Paul Ceasrine; 01-04-2012 at 12:10 AM. |
#18 |
Liked 4 Times in 4 Posts
Paul,
Was the 413 with the two inline fours ever a viable combo or raced by anyone? JimR
Jim Rountree |
#19 |
Liked 12 Times in 12 Posts
Didn't Don Garlit's run a 62 Dodge with a 383 motor with inline carbs on it or was that a 413 with inline carbs, I'm not sure.
. Last edited by Hemi Moose; 01-02-2012 at 02:58 AM. |
#20 |
Liked 5 Times in 5 Posts
