#1 | |
The first 2 years I ran my car I used an intake manifold from a dodge caravan. And cams that would check legal in a stocker. Camshafts were almost not available for a N/A engine (nobody had cores) My exhaust cam is a stock cam that has been welded to increase lift, Things as simple as a 2 step were a challange. I had a trans brake made one of 2 in the world. My final drive (rear end gearing to you RWD guys) ratio is 3.94, and thats with custom made gears. But little by little I'm getting it sorted out. I have had some help from the soft index. But with the amount of one-of's I need I deserve it.
Art Leong 2095 SS |
You can run a four valve, four cylinder in H/EA-we have one in my car-Al Ackerman built it using a block and head out of the Colorado pick-up-it is a 2.9 liter motor (177 cubic inches) in stock form-we race it at 170 cubic inches. For H/EA, the motor must use carbs and the weight break is 8.25 lb.cubic inch. Fuel injection can be used in L/A or L/AA and the weight break is 10 lb/cubic inch (2 valve) or 10.5 lb/cubic inch (4 valve)..
Professor Dave |
Liked 135 Times in 74 Posts
New car on west coast with 4 cyl honda engine Has gone .60 under
Josh lee H/EA Good to see new blood and manufacturer in comp Here is link http://honda-tech.com/showthread.php?t=3012466 |
Sounds like the Honda is run at 134"? How are the H/EA power numbers compared to the L/A and F/D?
I'm talking hp per inch here.... |
My engine builder (Al Ackerman) never tells me those things-since his motors have always made my car go fast, I've never really pushed him of the subject either. Plus the real value of a dyno is not what the HP numbers are but how the HP numbers change as you make a tuning change.
I'm sorry, I'm not really looking for specifics. More so, I'm wondering if the engines in the few 4-cyl comp classes all make similar #'s. I have no idea what it takes to be competetive in Comp., but it seams that all the competetive engines are quite large for 4-cylinders. I'm looking to run a FWD car in SS, with a 4-valve combo. Due to the high weight of a SS car, and the SS/CX class' 12lbs. per cu.in., I'll be somewhere in the neighborhood of 164" or so. That in itself is a pretty big 4-cylinder, but the 200" stuff like the F/D guys seem to be running is even bigger. I'd heard that there was someone running a 122" Honda in F/D, but that would require a car that's 40% lighter than a 200" Splayed valve deal.
I would really like to talk with someone that's running a competetive n/a Comp 4-cylinder to see if my thoughts of power requirements are even in the ballpark. It does nobody any good to spend a bunch of money to NOT BE competetive. I can be reached at brian@phenixindustries.com if anyone is willing to give me a little guidance. |
I have considered running a turbo-charged front wheel drive car in comp. Have you thought about that?
Here's our car |
Tim Kish, Larry Dowty, and myself run (or have run) FWD cars in SS/GS. We have different approches to the goal. Larry ran a Quad 4 engine and a manual trans. Tim runs a 120 inch neon engine and an auto trans. I run a 150 SRT4 block and an auto trans. All 4 valve heads.
All of us have run 13.0's or better. At 18 pounds per inch. And each of us has got the index hit. These 4 cylinders make a lot of power. But I'm not sure you can get a car light enough to run 12 pounds per inch. And expect to get an awful lot of hand made "one of's". And they aren't cheap. In superstock with the breakout I'm sure you can build a competive car, but in comp it might be another thing. One big problem is final drive (gear) ratio. Most factory final drives are in the low three's. And this makes for a major problem Welcome to the 4 cylinder world.
Art Leong 2095 SS Last edited by art leong; 01-18-2012 at 03:22 PM. |
