Old 10-19-2011, 09:09 AM   #31
Dion Hildebrandt
Dion Hildebrandt's Avatar
Default Re: Help!! Engine Miss
Originally Posted by Bob Gullett View Post
The problem you describe sounds familiar. I assume your combo is a quadrajet. You don't mention if you have tried a different carb. I have seen where a piece of something gets lodged in a jet and basically causes the engine to run extremely lean. It almost sounds like is running on 1/2 the cylinders. Just another idea. When reving the engine up what does the timing do? Does it stay steady?
Have you opened up the carb? What I quoted from Bob happened to me, I put my car in the trailer sounded great went to the track and wouldnt run. I changed fuel pump cleaned all the filters and lines, changed ignition boxes, plugs (which looked 'normal'ish) and wires, cap and rotor, checked timing chain and the timing, etc. was looking at the big dollar carb and thought 'naw it cant be that' put on my spare carb Voila problem solved. Took my carb down to Bob to have it looked at and there was a chunk of orange silicone plugging a jet. To this day I still dont know where that came from but no more running issues, hope this helps.
Dion Hildebrandt 6009 STK H/SA
Dion Hildebrandt is offline   Reply With Quote
Old 10-19-2011, 10:54 AM   #32
Dirk Olson
Liked 172 Times in 46 Posts
Ben,
Check the voltage at the MSD, voltage should not drop lower than 9VDC. I would check the grounds (no paint ,clean,etc.) May want to ground both heads.
I live in LaCrosse, so I am not to far away I could make a trip down if you want, Another B/S Guy in the Midwest COOL!
Dirk Olson
5036 B/S
Dirk Olson 5036 STK
Dirk Olson is offline   Reply With Quote
Old 10-19-2011, 11:06 AM   #33
Nitroman
Nitroman's Avatar
Strange that it ran fine on the dyno, only to put it in the car and something fail.... I had one that popped and cracked really bad but only under a load and further upstairs(3,000 and up). You mentioned that you literally replaced every ignition component in the system, even said you tried another distributor... Did you by chance try just a straight up HEI of some sort to hooked straight to the battery to eliminate anything else in the car ?? It's possible to come up with multiple bad boxes. What box was used on the dyno ?? One from your car ? Or one that was already there ? I don't think changing the switches did anything to you, the addition of ground wires I suspoect is because the new ones are lighted... I was gonna suggest magnetic pick-up until you said you tried the whole dist. Hmmm... this could prove to be interesting, especially since from the looks of things, you've been fighting it for better than 2 MONTHS !!! As they say "I'd rather be racing !!!"
Maybe go back and make SURE your big red & black to the battery are intact from end to end.
Just trying to help.
Danny Ellard
Witch Doctor Racing
V/S 3915
Nitroman is offline   Reply With Quote
Old 10-20-2011, 05:05 AM   #34
Ben Kallies
Dion,
I sent the carb back to Deano and made him aware of the issue. He completely disassembled the carb, and checked all of the passages. Everything looked good.
Dirk,
Thanks for the offer to help. I've got family in LaCrosse - beautiful area. Ground wires are my current focus. I'll be changing some things around even if it doesn't prove to be my problem.
Nitroman,
I plan to eliminate the vehicle wiring from the equation one way or another in the testing process. I think I'll start with what Alan suggested and run all MSD wiring straight to the battery to eliminate the rest of the vehicle wiring from the equation. If that doesn't do it, the next step is an HEI to eliminate the ignition as well. The second MSD box that I tried was brand new, and will be in retested in another vehicle this weekend or next, so that will confirm whether or not that box is good.
-Ben
Ben Kallies is offline   Reply With Quote
Old 01-22-2012, 05:59 PM   #35
Ben Kallies
Well, it's winter in WI, and I had to put my car to bed without having found a solution to the mysterious engine miss. I did however, make some progress in November.
I installed a brand new HEI distributor with a single wire going direct to the battery. In theory, this should eliminate the entire ignition system from the equation. Needless to say, the problem persisted.
With the HEI still in place, I installed another carburetor that Dean Oliver was kind enough to let me try. The carb was fresh, and set up for a small block, and a bit leaner than my other carb. With this setup, the miss was definitely less severe, but persisted nonetheless.
Feeling pretty confident about the state of the ignition and fuel system, I turned my attention back to the engine. I pulled the covers, and checked and reset all the valves. #4 intake was bit loose, but the rest looked good. I can't think of any other mechanical issues that would cause a miss like this.
I've got a couple of months to let the brain gears turn before I can go back to actually working on the car (damn non-heated garage), so I'd love some input regarding a good springtime game plan. We'll get it figured out eventually. Thanks
-Ben Kallies
Old 01-22-2012, 07:41 PM   #36
Greg Reimer 7376
Liked 719 Times in 220 Posts
Cool Re: Help!! Engine Miss
I thinkI'd start looking for a flat cam, especially an exhaust lobe.
Old 01-22-2012, 08:48 PM   #37
MAURICE BLENDHEIM
Liked 285 Times in 87 Posts
Ben... I would start with a compression test. You mentioned intake lash, any chance something didn't fall into the intake manifold between the dyno and chassis (maybe paper towel or a piece of rag) I would have a look at that intake valve spring also. From what I read it is a miss load or no load. For the heck of it check it again... 1-8-7-3-6-5-4-2. Good Luck!
MAURICE BLENDHEIM is online now   Reply With Quote
Old 01-22-2012, 09:41 PM   #38
Pvt Parts
Pvt Parts's Avatar
Two issues that I ran into with similar results. Super Stock Corvette.... fresh motor with engine miss. Looking at it at the track and thinking about pulling it out. I looked down and pulled on the main starter wire, the big one on the solenoid with the battery cable attached to it. It was loose, real loose like someone forgot to tighten it on install. Tightened the nut and the problem was fixed.
New Jerry Haas Comp car. Fouling plugs and killing coils in 4 to 5 runs. Chased the problem for half of the season. Finally drilled two holes in the frame tubes and ran a #10 wire from the frame tubes to each head under the header bolt. Problem fixed.
Maybe this will help. Good luck.
Old 01-23-2012, 01:09 AM   #39
Adger Smith
Liked 880 Times in 311 Posts
You have a PM
Adger Smith (Former SS)
Old 01-23-2012, 09:19 AM   #40
terry1
Liked 24 Times in 13 Posts
Smile Re: Help!! Engine Miss
Ben.You have a PM
terry1 is offline   Reply With Quote
