Old 01-26-2012, 03:14 PM   #1
Rusty Davenport
Liked 101 Times in 27 Posts
Question Pinion depth and shims...12 bolt question
Taking out a Richmond 5.00 gear and putting in a used US Gear 4.88......the US gear pinion depth has been done away with by a previous owner so I am playing with trial and error even more than usual.....if I hold the same pinion depth as the Richmond gear that came out I will have to add .090 worth of shims.....is that considered an unusual large amount of shims to any of you 12 bolt experts ??? (The pinion head of the Richmond gear is that much thicker......concerns me where to start...... I always read about starting at .035)
Rusty Davenport is offline   Reply With Quote
Old 01-26-2012, 03:23 PM   #2
Liked 1,909 Times in 427 Posts
Default Re: Pinion depth and shims...12 bolt question
Yeah, 0.090" of shim is a ton. I'd start with 0.035", and about 0.010" of backlash, and go from there.
Old 01-26-2012, 04:30 PM   #3
tj310
I did 2 sets last week .030 .038. gave up on pinion depth setters years ago. ---Trevor PS it's not a 3 series gear going on a 4 series carrier?
Old 01-26-2012, 09:10 PM   #4
Glenn Briglio
Glenn Briglio's Avatar
Liked 974 Times in 310 Posts
+1 Pattern, pattern, pattern. That's what it's all about.
Old 01-27-2012, 09:20 PM   #5
Greg Reimer 7376
Liked 719 Times in 220 Posts
Cool Re: Pinion depth and shims...12 bolt question
In my experiences of setting up rear ends,a 3 series gear set on either a 12 bolt or an 8 1/2" 10 bolt, an.030" pinion shim is usually about perfect. For a 4.11 to a 4.88,use either a.031-.032' shim, and with gears in the 5's or a 6.14, use a .033 shim The small pinions need to be set a little deeper in order to achieve a pattern centered on the ring gear. I probably have set up an honest 100 rear ends in my life.12 bolts are pretty consistant in what shim to use.
Old 01-30-2012, 10:26 AM   #6
Rusty Davenport
Talking Re: Pinion depth and shims...12 bolt question
thanks for all the replies, I'm trying to read the paint on the ring gear but that is a little more challenging than I anticipated. All the preloads are perfect, just the mesh torments me......may just put it together and run it !!!!!!!!!!!!! ahahahaahahahah
Old 01-30-2012, 11:03 AM   #7
SSGT Mustang
Liked 204 Times in 54 Posts
Do you guys get the click-click-click-click-click-click from your 12-bolt rear end gears after a few transbrake launches? I have a 8.8 that still has the right gear pattern (and no cracks or visual anomolies), but makes a clicking noise when I spin the tire. The noise started after about ten, 7000 rpm launches......
SSGT Mustang is offline   Reply With Quote
Old 01-30-2012, 11:47 AM   #8
Dirk Olson
Liked 172 Times in 46 Posts
I agree with Glen, Pattern in the key. I assume these are pro gears? .028 to .031 to start, look at the pattern on drive side. I like to be a slight heavy on the toe side to accomidate tooth deflection. Like about .008 on back lash on new set with good runout on spool. If runout is more than .003 you will need to open the backlash up so that you get no tooth binding. This works for me and I will get 200 to 250 passes out of a gear set then cycle them out. Hope this helps.
Dirk Olson
5036 B/S
Dirk Olson 5036 STK
Dirk Olson is online now   Reply With Quote
Old 01-30-2012, 12:05 PM   #9
Getting the pattern you want on a used set, especially without dimensions, can be difficult. Remember that the settings are the opinion of the guy who ran the Gleason machine on that set of gears. Also, you likely will not easily get the pattern you'd get on a set of Richmond race gears on that U.S. Gear set. It may be near impossible.
Old 01-30-2012, 12:43 PM   #10
Rusty Davenport
That is really interesting....would anyone let me text the pictures of the pattern to them for an opinion ??? Phone number ???
