Problems occur with stock rocker arms if they pinch the stud at full lift, shorter pushrods may help, we used to run stock Z28 springs.---Trevor
Liked 13 Times in 7 Posts
Paul,
Thanks for the info. My plans are to use a set of stock 441 heads 1.94 - 1.50 (press in stud) with z28 springs and aftermarket roller tip or full roller rockers. For some limited street time and some bracket racing. The camshaft will be in the ballpark of 327 / 350 hp cam or something similar below Camshaft Lift: .450 Intake /.460 Exhaust Flat Tappet Duration @ .050" (222°Int/222° Exh)
N/A |
Liked 327 Times in 121 Posts
Some heads might be fine but there is an inconsistency from head to head and stud to stud. If the heads have a good history a slight step up from stock should be OK
Liked 8 Times in 7 Posts
i've had the studs "pinned" before, might be an alternative for ya...
You're not going to break studs with that cam/spring combination, and you shouldn't be pulling studs either. If you want a guarantee, drill the stud bosses with a 1/8" bit and install hardened roll pins, or have a shop pull the studs and tap them for repair studs. (shoulderless studs)
#8 | |
Banned
Liked 235 Times in 110 Posts
Check to make sure the rocker arms dont hit the studs in the rocker ball slot at full lift if your using OEM or OEM style rockers. |
