Old 02-05-2012, 11:13 PM   #8
rustbucket79
Default Re: Maximum Valve Spring Pressure
You're not going to break studs with that cam/spring combination, and you shouldn't be pulling studs either. If you want a guarantee, drill the stud bosses with a 1/8" bit and install hardened roll pins, or have a shop pull the studs and tap them for repair studs. (shoulderless studs)
rustbucket79 is offline   Reply With Quote
