Old 02-17-2012, 01:18 AM   #21
sixty8
sixty8's Avatar
Default Re: Strange front brakes dragging
Originally Posted by ss/bs4457 View Post
Does anyone have any suggestions on how to stop this?
Jonathan Womack
I added some springs to apply force at the top of the pads to keep the pads parallel which prevents the light dragging. I used some old TH400 direct drum return springs which seem to work well. This will only work if there is nothing else wrong in your brake system.
sixty8 is offline   Reply With Quote
Old 02-17-2012, 09:57 AM   #22
John Dinkel
Liked 263 Times in 68 Posts
Thumbs up Re: Strange front brakes dragging
The springs are good. I did the same thing last summer. Got some springs at the local hardware store.
John Dinkel 3295 STK
John Dinkel is offline   Reply With Quote
Old 02-19-2012, 11:49 AM   #23
ss/bs4457
Thanks for all the suggestions. I think I'm going to try the springs after I double check everything else.. One side rolls ok.. The other side has a tight spot.. ( maybe warped rotor) . How free can a strange setup get? I know lambs stuff will roll for 30 seconds or more.... Crazy! So with the car on jack stands and the front wheel on, can I get it close to lambs stuff or will I be doing good to get a few revolutions out of it?
Jonathan Womack
ss/bs4457 is offline   Reply With Quote
Old 12-31-2023, 12:30 AM   #24
Tracy Robbins
Liked 25 Times in 11 Posts
Any idea how much the front brakes dragging affects e.t.?
Tracy Robbins
SS 9766
Tracy Robbins is offline   Reply With Quote
