Was trying to clarify if a stocker with an auto tranny needed a flexplate and trans shield. The rule books says for any car running 10.99 or quicker or 135 or faster, except in certain stock and super stock classes. In the stock section, I dont really see anything except for people running manual transmissions. I hope it runs quicker than 10..99 but it wont run 135 or faster.
I know in other classes it has a section that specifically states an auto needs a shield , but stock was kind of vague. Thanks to anybody that can clarify this. Chris |
Liked 1,830 Times in 415 Posts
The rule in Stock is 9.99. Or at least it was.
If you want or need a rule clarification, it is always best to get it in writing from Glendora, and keep it with the car.
Alan Roehrich 212A G/S |
Question to N.H.R.A. Technical services
From: peter ash Sent: Monday, February 20, 2012 3:09 PM To: #Technical Services Subject: Flexplat and transmission shields for Stock Class Cars Re; Flexplate and transmission shields for Stock Class running faster than 9.99 seconds Dear Mr. Bachelder; Are the Stock Class cars running 9.99 seconds or quicker exempt from the requirement of a Flexplate shield and Transmission shield? Thank you Peter Ash Reply; Peter Ash, NHRA Rule Book Page 6 Section 10A: Transmission case must be OEM or Aftermarket OEM Replica from a standard automotive application as found in the Official NHRA Stock Car Class Guide. Aftermarket case must meet SFI Spec 4.1 and 30.1 OEM case does not need to meet this requirement. Bruce B. Last edited by Peter Ash; 02-20-2012 at 08:50 PM. |
Liked 333 Times in 180 Posts
rule book says ANY car running quicker than 10.99 AND/OR135 mph must have both shields (flex/trans) and a ALSO SFI flexplate REGARDLESS OF CLASS unless the rule book specifically allows it--General regulations back of the rule book buried in the Auto Trans section--ya have to look for it---NO shields necessary if ya have an APPROVED aftermarket trans case BUT ya still need the flexplate---2012 NHRA rule book--Section 20 page 12 sub-section 2:14 spells it out for ya-- basically if ya can run faster than 135 MPH or quicker than 10.99 YES
#5 | |
Liked 4 Times in 4 Posts
Basically he didn't answer the question! You asked about flex plate and transmission shields and he talked about trans cases so I guess the question is still open. JimR
Jim Rountree Last edited by treessavoy; 02-21-2012 at 01:21 AM. |
it aint open look at my post there's yer answer--Bruce did not either read the ? or he answered the ? wrong---if ya go quicker than 10:99 or faster than 135 REGARDLESS of which class yer in ya need a shield EXCEPT if ya have an approved aftermkt case OR yer class is exempted(porsche/vw)---what dont ya understand here???????????????????--- ya also need a SFI flexplate !!! understand ???
10.99 or quicker SHIELD/PLATE 135 or faster SHIELD?PLATE-- FORGET BRUCE read the rule book its in there |
#7 | |
For some clarification I posed a more specific question to N.H.R.A. Technical Department
From: peter ash Sent: Tuesday, February 21, 2012 12:03 PM To: Bruce Bachelder Subject: Re: Flexplat and transmission shields for Stock Class Cars Dear Mr. Bachelder Thank you for your quick reponse to my inquiry. As I am not quite sure your answer gives me all the information I may require, I wish to rephrase my question. In Section 20, Page 14, Rule 2:14 of the General Regulations. Does the phrase(except some Stock and Super Stock classes as noted under Class Requirements) exempt a Stock Class Car using an OEM Automatic Transmission case, running 9.99 seconds or quicker and 135 miles per hour or faster, from the requirement of an SFI approved Flexplate Shield and an SFI approved Transmission Shield ? Thank you for your time. Regards Peter Ash ANSWER: YES IT DOES. Last edited by Peter Ash; 02-21-2012 at 04:12 PM. |
Thanks, Peter.
JimR
Jim Rountree |
#10 | |
Liked 502 Times in 130 Posts
Eric Merryfield 1883 STK |
