#1 | |
Liked 70 Times in 29 Posts
Why would or should a sealed 5 gal drum be any different than buying it out of a 30 or 55 gallon drum straight off the truck?
Chris Bowman The Mountain State Mustang 1984 Mustang GT350 |
[QUOTE=Chris1529;311009
Why would or should a sealed 5 gal drum be any different than buying it out of a 30 or 55 gallon drum straight off the truck?[/QUOTE] Chris - I wish I could tell you with 100% certainty why but I've never had a customers gas have a problem that came out of a sealed 5 gallon pail - some say its because air hasn't got to it .I'm told shelf life starts the moment the can is opened .
Jack Matyas 1547 FS/C 2015 Camaro COPO # 62- 2012 Camaro Convertible COPO |
Liked 13 Times in 9 Posts
VP has a high pop-off rate (ie., unstable). I've had Sunoco laying around from one year to the next with no issues.
I think many of the 'new' names in the fuel business are offshoots from when the Torco empire crashed. I found Torco to be very similar to Sunoco. Good fuel, and stable. Remember when testing different fuels you may need to change your jetting. Different fuels can have different sized fuel molecules, changing your mixture.
After changing the tune up, mine likes C11. I have never had a problem with fuel check. Even after sitting in plastic fuel jugs for the winter.
Ed Wright 4156 SS/JA |
#5 | |
Liked 269 Times in 99 Posts
Ed, What is your routine when storing the car for a few weeks between races? Was told with VP it is wise to fog the engine with Marvel Mystery Oil. This involves changing to old plugs for the fog down. At the next race restart with old plugs when MMO burns off install good plugs. I run a fuel injected car also and wonder about the caustic chemicals in VP. Thanks
#6 | |
#7 | |
Ran VP C-12 the end of last season. The exhaust valves were really beat up. Was told that is an issue with VP. Need to fog the engine when stored for more than a few days. The funny thing is that some racers who do not fog their engines make some of the best runs before the freshen up that exposed the beat up valve. So go figure but I would rather the engine come apart clean. Frank
#8 | |
