Old 02-24-2012, 11:31 AM   #17
Mike Croley
Default Re: Anyone test Renegade fuel ?
Originally Posted by 1320racer View Post
Mike perhaps you missed my post/question...
But are they a refiner/are they producing the fuel or buying the fuel and reselling and if not a refiner who is making the fuel they sell?
Never heard of them until a few months ago.
As for Torco, used it one time and never again. Leaked past my carb gaskets and stained my intake manifold. Sunoco nor VP have ever done that.
No , i didn't miss your post , i just wasn't sure what question you wanted answered .
I can't tell you too much about your Torco problem , could have been an issue with the brand of gasket you were using . Staining comes from the dye used in race fuels to distinguish one from another . Some companies use more dye than others , but all race fuels can and do stain . Race engine builders have long used the traces of dye to follow race fuel through the manifold and head ports to get an idea of flow .
Renegade hasn't done nearly as much advertising over the years as some companies . Doesn't mean they aren't as good or even better . Just means they spend their money on other things like R&D . They have recently stepped up the marketing , that's probably why you starting hearing more about them .
ALL race gasolines are refined , there's no other way to make race gasoline . They start with base stock . And then EVERY race fuel company buys compounds and chemicals from a number of sources to add to the base stock to create their own version of the best . And that's where the differences between race fuel brands come into play . Race gas formulas can be manipulated to make them do a wide variety of things . You can blend for max power , or you can blend for max torque . Or you can blend for mileage ( think NASCAR ) . And of course you can blend in certain compounds and chemicals to work with nitrous or supercharging/turbocharging . In F1 , race gasoline is also blended specifically for weight , every pound saved is an advantage .
Mike Croley is offline   Reply With Quote
