Old 02-29-2012, 03:56 PM   #1
Stewart Way
Liked 70 Times in 22 Posts
Default Re: High gear clutch slippage
First, I know you can adjust the clutch to stop the slippage in 4th. That wasn't the question, why it slips was. Maybe you guys are right. If you are using the clutch to shift or have a stocker type cluchless, where the engine is unloaded for an instant the load drops out the bottom (as would HP)so my theory may be flawed unless the slippage happens well after the gear change when the engine is climbing. If it happens at the change, it sounds like it could be the difference in resistance due to ratio changes, rolling resistance and aero effects.
But if you make a 1-2 gear change and the clutch has enough friction to hold it why doesn't it have enough friction to hold it on the 3-4 change. Same power applied to the clutch disc and same clamping force on the pressure plate. Goes back to my original theory. If you put more resistance to the engine being able to RPM it will produce more power and overcome the CofF of the clutch. Don't see how the same amount of power will overcome the Cof F in 3-4 shift and not the 1-2 or 2-3.
Here is my thoughts. You have a clutch set that will slip at 600hp. On your 1-2 change because the engine is allowed to climb at whatever rate it produces 550hp max. Then at the 2-3 change it climbs slower and makes 580hp. On the 3-4 change due to all the reasons we have stated the rate is slower yet and it goes above 600. Now you have slippage. Those numbers are likely larger than the differences would be in real life but you see my theory.
Again, my theory is only that and could be swiss cheese.
Stewart Way 2424 SS
Old 02-29-2012, 06:17 PM   #2
magnumv8
This falls back on the high school theory of "work".....if you put a load on a rope with a block and tackle pulley arrangement (say first gear) and then you(the engine) pull on the rope it is fairly easy to move the load ( the vehicle) .....but if you eliminate all the pulleys (high gear) it removes the mechanical advantage you had putting the full load of what you are trying to move on you (the engine) so it has to "work harder"....
An engine won't produce it's full power until it needs to, so even at full throttle maximum torque won't be achieved until the engine sees a full load where it is required to do the most "work"....most dyno rooms used by the OEM's in the old days where called "load cells" because that is the only way to get a true measure of an engines power....
So to answer your question it is because the engine has to work harder in 4th gear than it does in 1st,2nd, or 3rd is the reason for the clutch slippage....
D L Rambo....
magnumv8 is offline   Reply With Quote
Old 02-29-2012, 06:40 PM   #3
Stewart Way
DL
Thats kind of what I was saying. It made more power due to loading but then I did a google of 4th gear clutch slippage and found a writeup under worldphaco.net. At first I thought this kind of shot my theory that the engine makes more power(works harder) in 4th or at least that that is the cause of the slippage. But this writeup uses the theory of CEP (constant engine power) which is not real world. The writer talks about when you accelerate but doing it with constant power. Without additional power how do you accelerate? Not sure his calculations are valid in the real world.
Stewart Way 2424 SS
Old 02-29-2012, 07:31 PM   #4
Jeff Lee
Jeff Lee's Avatar
You are assuming the same RPM drop on each gear change. It is not. Look at your friends transmission gear ratio's. Determine the percentage of RPM drop in every gear. Then you will be able to see why there is such a difference going into 4th as opposed to going to 2nd.
Jeff Lee 7494 D/S '70 AMX
Old 03-01-2012, 08:20 AM   #5
69Cobra
Liked 2 Times in 2 Posts
Correct. The gear ratio percentage drop is going to have a lot to do with this as well as rpm's. For example if you have a 1.50 3rd vs a 1.20 3rd gear. The 1.50 3rd gear is going to put a lot more stress on the clutch when going into high gear vs the 1.20 3rd gear. Therefor you are going to have to put extreme amounts of base and/or counterweights to keep from driving through the clutch with the 1.50 3rd and this is going to have you chasing your tail on the starting line to find a balance for the starting line and high gear. Hope this helps.
Kris Rachford
69 Cobra 428CJ 4 Speed
C/S 3032
Old 03-01-2012, 11:22 AM   #6
Stewart Way
Lets back up. First. we were not testing a clutch car, we were just talking in the toter on the way back from running an automatic. The man who asked the ? has run gassers, SS, NHRA and IHRA Pro Stock over a 50 year span. We know how to adjust a clutch (sort of, we think). If it slips going into high gear we know what to do to stop it. The question was what causes it. Is it more HP, more torque, more resistance at the higher MPH or a combination of them?
With the up hill example, pulling it into high gear drops the rpm putting more torque and likely less hp on the input shaft.
If you look at 3rd vs 4th ratios a closer ratio will get you a higher 4th gear rpm at the change for more hp but less torque at the shift. But the closer ratio gets you a higher MPH at the gear change for more of the resistances. The 1.50 vs 1.20 3rd gear ratio example talks about the added "stress" on the 1.50 vs 1.20 ratio. Where does this come from. The engine. It seems to me that since the clutch is between the engine and trans that any change in ratios causing more "stress" has to happen by the engine producing more power since thats the only thing making power.
DL Rambos pulley example would seem to show that as the resistance increases for what ever reason the power transmitted increases. Get rid of the mechanical advantage of a pulley or gear reduction, it takes more power.
All good thoughts. Thanks and keep them coming.
Stewart Way 2424 SS
Old 03-01-2012, 01:31 PM   #7
Jeff Lee
Jeff Lee's Avatar
I'm pretty sure the question has been answered.
Old 03-01-2012, 07:12 PM   #8
Stewart Way
Jeff
Yes, 2 or 3 times but which one is right, or are the all right?. Being a Mech Engr I like a little proof and not just theory. Somewhere there has to be a test or paper or something to add fact to this. I am going to Kaase Racing next week for lunch. They have or had a dyno that ran thru a clutch and lenco. I'm going to check to see if when they simulated a run if they varied the rate of accel in each gear as it happens on the track and if they did what happened to the HP numbers.
If you think of it, next time you talk to you clutch buddy at Advanced (I think) would you check and see what he thinks. He likely has more experience and knowledge than the rest of us combined.
Right now I lean toward a combination of all the answers given so far and not just one.
If you use your example of the 3 to 4 ratio, on a tranny with 2.47-1.77-1.33-1.00 the 2-3 and 3-4 drop is the same, do you think the slip would then happen in 3 as well as 4? No proof needed, just your thoughts. You do have more experience at this than I do for sure.
Stewart Way 2424 SS
Old 03-02-2012, 07:40 AM   #9
goinbroke2
Liked 405 Times in 158 Posts
Stewart, in my example of driving an old truck up a hill;
In 3rd I could floor it all the way up the hill from about 1800 to about 4000 with no slippage.
In 4th I would slowly roll on the throttle and it would pull to about 2500 or so and then slip. This was repeatable as I'd back off and get lock up then add throttle until it slipped.
I'll stick with increased resistance since we're not talking blowing through the clutch on a gear change but after full lock up, then getting slippage.
DL Rambo nailed it.
Old 03-02-2012, 11:17 AM   #10
Stewart Way
Had the same experience in a 64 Rambler American with 3 on the tree. Only slipped in 3rd. Would bark 2nd but had to be gentle in 3rd. Not sure if it was turning or dragging the tire on the 1-2 change though.
I'll be in your neck of the woods in July-August. Meductic, NB. What part of NS are you in. Got a cousin in Wolfville, NS.
Back to the topic. Looks like were saying that without the mechanical advantage of the gear reduction, that in high gear the engine makes more power and overpowers the clutch? Will post what, if anything, I learn on my visit to Kasses shop next week.
Stewart Way 2424 SS
