Old 03-03-2012, 09:31 PM   #1
Mark Madison
Liked 32 Times in 9 Posts
Default Re: High gear clutch slippage
Rob might have you fooled with whatever B.S he spun regarding this issue, I'm Not. The fact is I paid $925.64 for a clutch rebuild and the clutch came back to me with warped heat shields. So warped that when Mike Sullivan disassembled the unit to weight the leavers and check the spring rates to configure a clutch program, he sent the unit back to me and said the clutch needed to go back to Rob to have the heat shields fixed they where not flat! After I complained Rob replaced the flywheel shield and chucked the clutch side in a lathe and cut.it. So much for not grinding these parts flat. If you would like I can run up to my trailer and retrieve the warped heat shield and post pictures for all to see.
In this thread you state that a clutch rebuild from Rob is $900.00 and replacing heat shields is a normal part of a clutch rebuild . The question that has not been answered is why where mine not? I hope Rob made a photo copy of the check for $925.64 because thats the last of my money he will ever see. Now jump back on the phone and see if you two can put a positive spin on this .
Mark Madison is offline   Reply With Quote
