Liked 759 Times in 379 Posts
I don't know about "rockstar" but I have had women tell me I rocked their world
![]() Rich, sounds good, oil pressure good. On the Moroso Trick springs, the complaint I heard from many going back over 20 years is the quality of the spring is no longer what it was and depending on who you talk to, there are some that have stated the springs were dead in less than a full season of racing. Who's the friend? |
Liked 544 Times in 213 Posts
Tony Monico......
He has a very nice 72 Nova.....ran a little S/ST and some bracket racing in the past. Used to run Mid 10's with a 350. He built a 502 himself......He's trying to get out and make license runs soon. Glad to hear Ricky is up and running fine and hopefully it stays that way for a season.....
Liked 46 Times in 29 Posts
Santhuff springs are machined flat on both ends of their springs and you have to remove 1 coil on 1 end so the fit in spring pocket in lower control arm of Camaros, chevelles, novas etc. You can fit the flat end in it if you like, I would not as it does not fit into the pocket in the lower arm then.
I cut mine. fit fine. Santhuff says no problem cutting them as first coil is a dead coil as they put it. |
#4 | |
Liked 31 Times in 10 Posts
Michael Brand II 505B - F/SA |
I asked bob gonier, a member here what coil spring is he running on his small tire, super street Nova who's build was featured by Evan Smith in National Dragster last year and he told me told me he runs Santhuff's 180 lb. spring. He did say however that the springs are at coil bind and the lower control arms on the bump stops.
Liked 427 Times in 97 Posts
QUOTE=1320racer
On the Moroso Trick springs, the complaint I heard from many going back over 20 years is the quality of the spring is no longer what it was and depending on who you talk to, there are some that have stated the springs were dead in less than a full season of racing. X2 on the "Trick Springs" (hint) go back and read post #5 and "use what's suggested" some of the "best kept secrets" are right in front of you! |
Santhuff 180's here with 1900 lbs of nose weight.
I think the 200's would be ideal for the combo.
'67 Camaro 1.25 5.77 @ 118 |
