Yes, Because it's a wagon you can put the cell below the floor.
2009 V/SA Record Holder |
Liked 999 Times in 202 Posts
I run a 10 gal. aluminum, and i take out the foam.If you run into a problem with your fuel not checking,it is easier to get it cleaned out.Does anyone else think it is a good idea to put in a fuel shut off in the line? With the fuel cell now mounted high in the rear of the car,it is easy for it to drain out if a line is cracked open.A fuel shut off makes it easier,and safer to service a pump or regulator,or to just drain the system.I like the 10 gal. because it is easier to add a little weight if you need to.The tanks with the tabs welded on them are simpler to mount also.
#4 | |
Here is a pic of my new setup. It's a Jeg's 5 gallon with 2 #10 outlet bungs, a #8 vent and a #8 return. I had my local race shop make a CM mount and tig on some attachment bungs.
'67 Camaro 1.25 5.77 @ 118 |
40 Coupe,
Do you have the part nuber for that cell by a chance? Thanks Tim |
Jegs 555-15315. $131.50 with discount.
