Old 03-16-2012, 06:38 PM   #2
Tod Lane
Tod Lane's Avatar
Liked 2 Times in 2 Posts
Default Re: info on caltracs and tire?
Originally Posted by bigdaddy4026 View Post
hi! i have not raced in 15+ years have been jr racing with my son for 5 years, so i have a few questions
i found a stock suspension 1967 camaro with a fiberglass front cap,that i am building for my son (and i get to get in till he is old enough), trying to start with suspension and work my way up, it will be set up with a
12 &1/2 to 1- 355 small block , th350, 8inch converter( the 1st owner said 5300 stall), 488 gear,
looking to see what size rear tire should i run (30x9?)
i really don't want his 1st car to leave as high as you guys ,so can i use caltracs (or something similar) to keep it down and still be consistant
thanks for any imput at all (good or bad)
Why would Cal tracs keep it down?
To be consistant you need to hook...
The wheelstands can be controled with shocks in the front generally speaking. Or wheelie bars if needed.
How big a tie will ft under the car? What rpm are you wanting to trap at?
Tod Lane
Swartz & Lane 66 Nova
Swartz & Lane 79 H/CM Trans Am
Tod Lane is offline   Reply With Quote
